European add-on rotary for plasma?
Re: European add-on rotary for plasma?
that is about correct, but you may need to change the current switches on the driver for the bigger motor and the steps per calibration.
Reb0rn
Post by Reb0rn »
I am aware of that, not a big issue
Reb0rn
Post by Reb0rn »
When i compleet the wiring (using mach3 controller), do i need to do some diffecult programming? or is it just the steps/accellerations etc inside of mach3?
yes the info is in the Motor tune sections, with Mach you can also do the steps per calculations very quickly
Reb0rn
Post by Reb0rn »
i am thinking about the z-axis. when i want big pipes, but also small ones, i need a z axis that can rise about 25-30cm, , any suggestions?
i was thinking about the normal ones with 30-40cm threaded spindel with nema 17 motor, but than with the torch hanging 30cm below the rail blocks.
so when i want to cut a small pipe, it can get down low enough, and high enough for bigger pipes.
I would use a machine torch to add with the adjustability, you can just slide the torch up and down in its holder. That with a little longer Z axis motion you should have enough to do what you want. I would also use a nema 23 somewhere about a 300 OZ range.
Tom - great suggestion on the machine torch for increased adjustment range (and ease of adjustment). My tube cutter setup as a range from smaller diameters up to around 13" OD and I use a hand torch. But on mine the cradles that support the tube are adjustable.
Nice David, the designer was forward looking to build in a good range of use, a real tool guy. :Yay not just a sales guy :HaHa
Yes Tom - I very much agree! I think Plasmacam puts some great design and engineering into their products, and I just tried to improve the '"convenience factor" with my stand-alone version.
Reb0rn
Post by Reb0rn »
acourtjester wrote: Thu Dec 01, 2022 10:04 pm I would use a machine torch to add with the adjustability, you can just slide the torch up and down in its holder. That with a little longer Z axis motion you should have enough to do what you want. I would also use a nema 23 somewhere about a 300 OZ range.
I have a machine torch on my plasma table, but for now i want to use the hand torch that came with the cutter itself, so i dont have to change em all the time.
I was thinking of the average floating z axis, but than with a long spindle and also a long plate going down to hold the torch.
Reb0rn
Post by Reb0rn »
Maybe a stupid question,
How do you connect the plasma cutter to the BOB? Does it need something in between them? to turn plasma on and off.
No stupid question, very valid one. Some BOBs have a relay on the board or you may need to add an external one. In the controller software you would select a output pin to trigger the relay or external relay. Some software have a button to click on to fire the torch for testing. IN the post processor the command M3 is normally torch on and M5 is off written in the G-code. This output will be wired to the Plasma unit, Hypertherm has a plug on the back with 2 input pins for torch fire. Some of the less expensive plasma units have a 2 plug in the front to hook the trigger wires from the torch (hand Held) this is where you would wire in the BOB trigger signal. This is a contact only no voltage needed.
Reb0rn
Post by Reb0rn »
i was looking at a xhc controller, to use with mach (i already have mach3).
https://hardware-cnc.nl/winkel/cnc-best ... -ethernet/
My plasma has 4 pins, in the guide stated as followed:
** Pin 1 and 2 – Output, provides the OK to move signal output which is a normally open, dry contact closure when the plasma arc transfers
*** Pins 3 & 4 – Input, which requires a normally open dry contact closure to activate the plasma
does it matter wich pin i use for what? U said i can select it, but also that M3 & M5 (it is aswell for me) is torch on/off and that i need to connect those.
Reb0rn
Post by Reb0rn »
Alright, the stuf got in and i started with trying to make 1 stepper work. it does turn, but always the same direction. Is it a wiring mistake? Or is it some programming stuff?
Ok when a stepper only turns in one direction its because it is not getting the DIR change in voltage. Plus 5 volts is for one direction and zero volts for the other. You may have selected an output pin that is not a DIR signal. If you have a broken wire the motor will grunt and does not know which direction to turn and just vibrates.
Reb0rn
Post by Reb0rn »
hmm thats kinda weird, because i cant find a 5v port. on my XHC control card i have pul+ & - ans also Dir + & -, connected all 4 on the driver.
Reb0rn
Post by Reb0rn »
never mind!! bad connection in 1 of the 4 :p
