Hello all. My name is Dan and I'm glad to have found this forum. I have a Wright CNC 4x4 table and am happy to report that it works as it should. I say this because those who bought from Wright after did not fare so well. Anyway, I am just a hobbyist and enjoy making parts for project vehicles. I've been working (slowly) on a land speed racing car (pic attached) and have other little projects going on some others in the shop. I model in Fusion 360 and QCAD and have recently started working with an SLA 3d printer.
The next plasma related project I want to wade into is automated tube notching. I have begun modeling a design and to investigate the software side. This is where I will need some help.
Dan
New to community from Oklahoma
Re: New to community from Oklahoma
Welcome Dan! Great looking shop and definitely a cool project car you have there, a plasma table is a dream come true for building stuff like that. Would like to see more of that build as the project moves ahead, very cool.
I have tried notching round tube so many different ways and always end up coming back to doing manually with a bandsaw and a 4.5" grinder. If you plasma cut the notches you need to grind it back beyond the heat affected zone anyway so no time is really saved I have found.
- Joe Jones
Why would you need to do this? The pipe is going to be heat affected when you weld it anyway. You can anneal the welded joints with a rosebud tip on an acetylene torch, to remove the brittleness that leads to cracks. I see no point in grinding back heat affected cuts.
Very fun project! Definitely a labor of love! You have more energy than I do. Good luck with the car. Post follow up photos as the project progresses.
Franklin, KY., USA
Samson 510 & 4x4
CreatBot D600 PRO 3D Printer
12 Lasers
FREE DesignEdge Training!
Samson 510 & 4x4
12 Lasers
Welcome aboard Dan! Nice looking shop you have there. I'm interested to hear more about your plan for an automated tube notcher. I see no reason at all why the "heat affected zone" would need to be ground off or otherwise removed, particularly for roll cages and such. But perhaps this all depends on the alloy being cut. In the old days when the slingshot dragster frames were welded together from chrome moly, the finished welds were either torch annealed or the entire chassis was put into a large over for annealing. What material do you plan to notch and what is your particular application?
I have a cnc rotary cutter built from Plasmacam parts that works quite well. It is great for all sorts of tube "notching" or "fish mouthing". Do you plan to add this capability to your existing Wright cnc table as an attachment, or build a stand-alone unit? I will look forward to hearing more about your project.
Ok not to put down a rotary tubing cutter for a CNC table but here is another idea for a dedicated fish mouth cutter.
There are others who just make a bushing type tube to slip over the tube you want to cut and use for a guide for hand cutting. Real simple if you only do one or two sizes of tube. A bushing is make for each angle of the cut.
acourtjester wrote: ↑Thu Jan 19, 2023 10:16 am Ok not to put down a rotary tubing cutter for a CNC table but here is another idea for a dedicated fish mouth cutter.
Nice find Tom! I will most definitely check these out.
- rdj357
Welcome! I'm over here on the eastern side of the state!
Robert Johnson
Learn Plasmacam Workshops
Learn Plasmacam on Facebook
Learn Plasmacam on YouTube
thanks
sonbakler wrote: ↑Wed Jan 18, 2023 8:26 am Welcome Dan! Great looking shop and definitely a cool project car you have there, a plasma table is a dream come true for building stuff like that. Would like to see more of that build as the project moves ahead, very cool.
Thanks! Yes the plasma table definitely helps with my projects.
DJA wrote: ↑Thu Jan 19, 2023 8:26 pmsonbakler wrote: ↑Wed Jan 18, 2023 8:26 am Welcome Dan! Great looking shop and definitely a cool project car you have there, a plasma table is a dream come true for building stuff like that. Would like to see more of that build as the project moves ahead, very cool.
