White out Board
White out Board
Just wanted to share this. Since adding the plasma table to the shop I've been drawing out parts and such on single sheets of paper then upgraded to a roll and then I just recently realized I had a 4'x6' white out board not being used I put it on the table and was amazed!! (lol), other than making another hole (tapered) in my super simple pen?marker holder for the fine tip dry erase marker I was astonished all I had to do was wipe it off and I could almost utilize my whole table surface and draw multiple times, it certainly beats taping or weighting down the paper. Hopefully this can be useful info to some one.
RAYZORcut
RAYZORcut
Re: White out Board
have you mistakenly used a Sharpie yet? You must move quickly after, if so!
Re: White out Board
Now that's a great idea!
Re: White out Board
Thanks for sharing your optional attachment to your table, more member more ideas more tools.
Re: White out Board
Great idea, love the creativity
- SegoMan DeSigns
Re: White out Board
Never underestimate the creativity of this forumRAYZORcut wrote: Thu Feb 09, 2023 7:20 pm Just wanted to share this. Since adding the plasma table to the shop I've been drawing out parts and such on single sheets of paper then upgraded to a roll and then I just recently realized I had a 4'x6' white out board not being used I put it on the table and was amazed!! (lol), other than making another hole (tapered) in my super simple pen?marker holder for the fine tip dry erase marker I was astonished all I had to do was wipe it off and I could almost utilize my whole table surface and draw multiple times, it certainly beats taping or weighting down the paper. Hopefully this can be useful info to some one.
RAYZORcut
- SegoMan DeSigns
Re: White out Board
What's your preferred cleaner for the sharpies? Denatured alcohol works good..martyy wrote: Thu Feb 09, 2023 8:24 pm have you mistakenly used a Sharpie yet? You must move quickly after, if so!
Re: White out Board
Just make hole a couple thou bigger then the marking pen/marker etc... zip tie around pen/marker with a little weight over top, I use a socket, works pretty good.
RAYZORcut
RAYZORcut
Re: White out Board
Just regular white out board eraser, they are dry erase markers.
RAYZORcut
RAYZORcut
Re: White out Board
I should mention I got the simple pen holder idea from table builder.
RAYZORcut
RAYZORcut
