Newb from Canada
Newb from Canada
Good day! I am so glad I found this forum! Lots of great info on here from lurking for a bit. I am hoping to learn many great things on here and hope to eventually build my own plasma table
Re: Newb from Canada
Welcome to the site. Plenty of DIY builders here and a forum specific to DIY projects here https://www.plasmaspider.com/viewforum.php?f=103 Post your questions and progress once the project starts
Welcome aboard Magna DIY is supported well here and many have been help along the way. Feel free to look using the search function in the upper right or ask questions about suppliers, software, and electronics.
Welcome to the forum! As Tom and plasmanewbie have mentioned, there is a wealth of information to be had here with respect to DIY tables, controllers, etc. What software - if any - are you currently learning to use (or already using) for your design work? What size table are you planning, and what if your budget for your build?
Thanks for the welcome guys! I am planning on using Fusion360, which is another reason to get on the board. I inderstand it is free for personal ise, unless I learn differently. Learning it shouldn’t be a problem, my wife does drafting and uses CAD every day. I am planning a 24X36 table. I know its a bit of an odd size, but its what I can fit in my shop. My budget less new plasma machine is about $1200 canadian
Here it the link for the free hobbyist version of Fusion 360.
https://www.autodesk.com/products/fusion-360/personal
Langmuir Systems has some great Fusion 360 tutorial videos geared towards cnc plasma cutting which I highly recommend.
Good luck and let us know if you have questions.
https://www.langmuirsystems.com/software/fusion
Thank you so much!!!
