Wanted - H1 Hummer Wheel Centers / Rock Rings
Anyone have any wheel centers for re-centering H1 Hummer double beadlock wheels, any design, any bolt patterns ? Also any diameter or pattern rock rings ? Thanks.
Re: Wanted - H1 Hummer Wheel Centers / Rock Rings
from fabricators file exchange
Reason: Sample image added
Many thanks for posting the files.
I'm still hoping to find files with different designs and although I needed rings for the 16.5" H1 Hummer wheels, I'm still trying to find different diameters as well.
I'm also still trying to find files to cut replacement wheel centers in as many different designs as possible.
I'm trying to locate files outside of plasmaspider as well and if I have any luck I'll be sure to post them here to share with others.
Again, Thank You very much, much appreciated.
look at w.stazworks.com you can see the designs they use. for the designs that cut lots of metal out they use thicker steel. 5/16, 3/8 ect.
