Universal mini skid steer mounting plade
looking for a toro dingo mounting plate DXF
Thanks in advance!
Thanks in advance!
Re: Universal mini skid steer mounting plade
This would be easy enough to draw up from scratch. Here are some of the critical dimensions. What drawing program are you using? Let us know if you need help getting started with this one.
Design edge pro
My concern is ive ordered quite a few of these mounts in the past, some of them simply just don't fit. I was hoping someone had one that they've tested and knows works... I build attachments for dingos but do not own one myself, therefor, no way of testing.
Perhaps find a friend or customer who does owe one and work with them to do the test fits. If you are planning to sell these, then yes I agree you want them to fit.
Rent a dingo for the R/D
I JUST built one this weekend for my tx420 and stuck a ball hitch on it to move my trailers around my yard. Didn't use a full plate though, just cut up some rectangles from scrap pieces I had laying around and welded it up.
I'll make a drawing tonight if I've got time.
What types of attachments do you make? I've been looking hard into things I could make some money off of.
Unfortunately there are a lots of manufacturers selling these sorts of attachments. It's probably hard to compete with products already mass produced and most likely coming from overseas. But good luck with your search.dtdetail wrote: Mon May 29, 2023 1:34 pm What types of attachments do you make? I've been looking hard into things I could make some money off of.
here is the blank toro dingo quick attach plate i made an tested on 2 of my dingos. fits like a glove.. cut out of 1/4in.. cut the pin bushings out of 3/8ths. i scaled it to .03937...
Hey, thanks hardworker I know a guy who could use this. Appreciate you posting it.
Tracker CNC 4x4
Buckets mostly. Not a great market but it brings people to my shop. I mostly do repair work.dtdetail wrote: Mon May 29, 2023 1:34 pm What types of attachments do you make? I've been looking hard into things I could make some money off of.
Thank you so much!!!
