slat cleaner
slat cleaner
Here is a simple design that works pretty good to clean the slag off the table slats. its far from perfect but it certainly helps. feel free to improve or modify. i just welded a .625 solid rod for a lever/handle. finally friday enjoy the weekend!
![Image](https://www.plasmaspider.com/images/SlatCleaner.JPG)
Re: slat cleaner
WOW, what a simple tool. I will cut one and see how it works
REX
REX
Hypertherm 65
Hypertherm 65
Re: slat cleaner
Thanks, will check it out also.
Precision Plasma Patriot 4X8, water table, Price THC, UC 400ETH, Floating head
Hypertherm 45XP - Machine torch
UCCNC, Sheetcam, Inkscape/Corel X5
- Joe Jones
Re: slat cleaner
I use a 2 foot length of three-quarter inch all thread. I run it up and down along the grates vertically, and it knocks all of the dross off and leaves the grate intact.
Franklin, KY., USA
Samson 510 & 4x4
CreatBot D600 PRO 3D Printer
16 Lasers
FREE DesignEdge Training!
Samson 510 & 4x4
16 Lasers
- tinspark
Re: slat cleaner
I have in the past hammered it off, which works, but I am not crazy about all of the percussion meeting the sensitive electronics.
This might be a great grate (pun intended) life extender, opposed to changing out my custom 1/8" x 2" flat bar grates.
Doug,
4x4 GoTorch- expanded
Hypertherm 45XP-
**CAUTION**- "Does Not Play Well With Others"![Smile :)](./images/smilies/icon_e_smile.gif)
Hypertherm 45XP-
Re: slat cleaner
Hardworker - this is a great looking tool design and I will most likely try it out when I get a chance. Thanks for sharing your work.hardworker wrote: ↑Fri Aug 11, 2023 10:31 am Here is a simple design that works pretty good to clean the slag off the table slats. its far from perfect but it certainly helps. feel free to improve or modify. i just welded a .625 solid rod for a lever/handle. finally friday enjoy the weekend!
Re: slat cleaner
Grate idea! Curious to try and see how well it works, I too have always used the "smash it with a hammer" technique.
Re: slat cleaner
Just curious to see what everyone’s thoughts are if anybody has had a chance to try this out yet…?
- Joe Jones
Re: slat cleaner
I have used all thread for a long time to clean the grates. You simply slide it vertically up and down as you move around the insides of the grate squares. Just be sure it is long enough to prevent you from slamming your hand down onto the grates on the down stroke!
Franklin, KY., USA
Samson 510 & 4x4
16 Lasers
Samson 510 & 4x4
16 Lasers
