THC IPM
Gogo
THC IPM
Post by Gogo »
Trying to fine tune my table and I think the THC speed is too fast. There is a reduction factor on the torch travel speed of a percentage, What factor are most of you using for 14 gauge or thinner. Im cutting great on plate but the gauge sheet is giving me some issues and I can see rapid movement on the torch head.
Hypertherm fine cut 35 to 45 amps recommendation for the reduction factor? Was going to set it at around 20% of the travel speed and go from there as a starting point unless someone has it dialed in for this type of cutting.
Re: THC IPM
You may be a better reply if you state the controller and the software you are using. Some of what you are talking about is controlled by either the G-code or the configuration of the controller. I have used a few different THC unit and they don't control the speed.
Gogo
Re: THC IPM
Post by Gogo »
The controller sets it as a percentage of the torch XY speed given. This is just for up and down IPM baseline . All the other stuff Im good on.
kicktillmonday
Re: THC IPM
Post by kicktillmonday »
With the info your providing I think that the best would be to use the smallest percentage you can and increase it if you find it is not reacting fast enough as the material warps.
DIY 4x8 table
Powermax 65
