Razorweld 45 x45 torch cnc fine cut IPMs HELP !!!
I have a razorweld 45 with x45 torch with fine cut consumables. Looking for IPM chart for 10 gauge and smaller. Is there any charts out there or what are IPMs that people have found that work for the razorweld 45.. Thanks Dave
Re: Razorweld 45 x45 torch cnc fine cut IPMs HELP !!!
Most likely you will need to generate your own. This requires making a series of straight cuts at different speeds and recording the results. You check the cut quality and dross amounts for each condition and select the ones that best reflect the outcome you want. You repeat this for each metal thickness and amp settings. There have been posts here in the past talking about this by other members, use the search function in the upper right for a look around. You also may download the Hypertherm manual for their 45 to give you some starting points from their charts.
Have never worked with that machine but Toms got the plan. Download the Hypertherm 45 manual for decent start points and do a series of straight line cuts documenting the best results. Too much dross, speed it up, not cutting through in some spots slow it down.
