importing metric files and converting them to inches
Fastyankee
Post by Fastyankee »
I have several files that were drawn in Metric and when I import them in they come in way to big. I need to scale them to inches. I tried scaling and clicking on the entire image and imputing 1,25.4 I also tried 1:25.4 with no luck. I can scale it by percentages and that seems to work but I really need to have the parts to the right size.
Does any one know how to convert percentage to inches when scaling a part?
Ink scape does the conversion when you import a part.
I receive a lot of files in metric so this something I will need to do on a regular basis and a good topic to cover.
Thanks for all the awesome help.
AJ
irondeuces@gmail.com
Pulmax
5x10 Star Lab plasma, scribe, pipe cutter
60 ton 53” press brake
JD2 tube bender
Hulk Tube bender
Slip roll 3/16th capacity
Ink Scape
Sheet Cam
Enroute6 user
Design Edge
ROKCRLER
Re: importing metric files and converting them to inches
Post by ROKCRLER »
Which software are you using?
To convert mm to inches you need to divide the value in mm by 25.4
In the software you can change the document properties from metric to imperial then save the drawing.
4x8 Dynatorch
PM85
~Mo~
Fastyankee wrote: Mon Nov 04, 2024 3:06 pm I have several files that were drawn in Metric and when I import them in they come in way to big. I need to scale them to inches. I tried scaling and clicking on the entire image and imputing 1,25.4 I also tried 1:25.4 with no luck. I can scale it by percentages and that seems to work but I really need to have the parts to the right size.
Andrew - as I told you during our phone conversation - type in "1/25.4" for your scaling factor. The "/" means divided by, so one divided by twenty five point four. Or type in the result which is 0.039370078. This is because 1 inch = 25.4 mm.
For any Design Edge operation where it asks you for a number - you can type in a fraction - like "1/2" for one half, "1/3" for a third, "1/10" for a tenth, etc.
1/2 = 0.5, 1/3 = 0.333333, 1/10 = 0.1, and so on. It is often quicker to enter the number in fractional format than to use your calculator to do the long division and then type in the result.
ROKCRLER wrote: Mon Nov 04, 2024 4:13 pm Which software are you using?
Mo - Andrew is using Design Edge.
Andrew - here are some screen shots that may help you.
Fastyankee
Dave
I did exactly that and it is not coming in right.
AJ
Pulmax
JD2 tube bender
Hulk Tube bender
Ink Scape
Sheet Cam
Enroute6 user
Design Edge
Fastyankee wrote: Wed Nov 06, 2024 8:52 am Dave
Put some dimensions on your imported file before you scale it. Perhaps it is was not scaled correctly to mm when saved from the original program.
If you try my example and draw a square that is 25.4" x 25.4" and then scale it by a factor of 1/25.4 - the result will be a smaller square with dimensions of 1" x 1".
When it asks for the scale factor, you type in 1/25.4
Also you only click once on the drawing before you scale it. If you click twice, it will think that you are entering the dimension you want for the distance between the locations you clicked on.
Also - post one of your original files here and I will check it out.
Fastyankee
I figured out I think why it was not working.
AJ
Pulmax
JD2 tube bender
Hulk Tube bender
Ink Scape
Sheet Cam
Enroute6 user
Design Edge
Fastyankee wrote: Wed Nov 06, 2024 9:45 am I figured out I think why it was not working.
Select the drawing on your monitor.
Type S
Click once anywhere on the selected drawing
Type 1/25.4
Press the Enter key on your keyboard.
Andrew - perhaps you could share what you figured out so that others may benefit.
Fastyankee
Dave
it was the way I was imputing the info. I was using 1:25.4 instead of 1/25.4
AJ
Pulmax
JD2 tube bender
Hulk Tube bender
Ink Scape
Sheet Cam
Enroute6 user
Design Edge
Fastyankee wrote: Thu Nov 07, 2024 5:55 am Dave
Andrew - happy to hear you've got it figured out.
