LDR bearings escaped
ColoradoWayne
Post by ColoradoWayne »
I just read the devastating news about Dan and LDR. Very sad! I have a 4x4 table I bought from LDR 11 years ago next month. It has been a GREAT system. This week I was surprised by ball bearings falling on my table from the torch mechanism. I have never dug into the machine before, but I guess it is time. Anyone been here before that can share some knowledge/advice.
Wayne
LDR Motion Systems 4 x 4 water table
Hypertherm Powermax 65
Re: LDR bearings escaped
The liner bearing are easy to find on different sites, you just need to measure the diameter of the shafts to order new ones. I use similar ones on the table I built.
Her is an example from amazon, You cut the length from longer ones with a cut off saw (angle grinder 4.5" type). I'm sure if you look around you can find shorter kits for less money.
VEVOR Linear Rail Slide SBR16-800mm 2 PCS and 4 PCS SBR16UU Slide Blocks Linear Guide Rail and Bearings Kit for Automated Machines DIY Project CNC Router Machines
ColoradoWayne
Thank you, you nailed it. That is exactly what the problem is.
Wayne
Tom offers some good advise here. I purchased similar linear rail bearings from Amazon a few year ago for my diy router/engraver table build.
