Finished coat rack
Finished coat rack
Here is the coat rack I cut out the other night and fabricated for an avid duck hunter. This was the cut I mentioned when my consumables finally gave out! I was surprised at the results as some detail is only 1/16" wide! Thank for the fantastic file Jason! It will hang in his garage where he will have his duck hunter club over for parties. He said to expect many wanting the same thing! It is 47" across by approximately 17" tall.
Re: Finished coat rack
Looks great!
Curious, is the detail on the jacket a cut path (loop w/in-out) or a single line? I looked up close and cannot see a pierce point! I usually have a blow out around the pierce.
WSS
WSS
They are just a single line cut. There is a slightly larger point at each pierce. I use "finecut" consummables about 75% of the time as I do much in the way of signage.
when you say "finecut" consummables are you talking about like a 80amp tip or 40amp?
finecut is hypertherm tips that are 40 amp and used for .125 thick and under
