Skillet Art
Skillet Art
Some of my skillet art. These are brand new Lodge skillets I totally destroyed.
Dave Hanks
Dave Hanks
- parrotlady
Re: Skillet Art
cool! I always wanted to do a design on a shovel
- AnotherDano
Re: Skillet Art
What a cool item.
What did you run into, cutting that cast iron?
What should we look out for?
Details, please...
Details, please...
Dano Roberts
droberts@ironpequod.com
PlasmaCam DHC-2 v3.11
Hypertherm PowerMax-30
Re: Skillet Art
It took me a while to figure out how to cut it. It cuts like butter once you dial it in. I cut these from the bottom backwards on a 45 degree angle. Very carefully chip off slag - there won't be much if you have the plasma set right. Then you need to coat it with cooking oil and bake it to keep it from rusting. The Lodge skillet website tells you how.AnotherDano wrote:What a cool item.
Details, please...
Dave Hanks
Re: Skillet Art
Neet idea, thanks for sharing. Would you mind sharing the cutting system you are using & the settings you came up with?
Danny
Danny
Re: Skillet Art
I use a Hobart Airforce 375 with a Plasma Cam machine. I set it at 25 amps and speed of 9.5 ipm. Had to alter my table and build a jig with a flip clamp on each handle to hold them. I locate them on the top rim upside down and 2 places on the round part and a locator stop for the handle. They are castings and are real close dimensionally. Once you find the center of the first one they're all in the same place. Make sure your webs are thick because cast iron is hard as diamonds and will break easily when you're chipping off the slag. I use a plastic mallet with a small sharp chisel to remove slag.mdwalker wrote:Neet idea, thanks for sharing. Would you mind sharing the cutting system you are using & the settings you came up with?
Danny
Dave Hanks
- AnotherDano
Re: Skillet Art
Thanks Dave. Good to know you used a PCam, so do I and was wondering it it would fit.
Dano Roberts
- Scratch
Re: Skillet Art
Don't the eggs run through all those holes in them pans...?
Re: Skillet Art
You just have to turn the heat up and cook em real fast!Scratch wrote:Don't the eggs run through all those holes in them pans...?
Dave Hanks
Re: Skillet Art
Thanks for the info Dave. Nice work & neat idea.
Danny
Danny
Re: Skillet Art
You're welcome. That's what this site is all about.mdwalker wrote:Thanks for the info Dave. Nice work & neat idea.
Danny
Dave Hanks
Re: Skillet Art
Do it! What are you waiting for?parrotlady wrote:cool! I always wanted to do a design on a shovel
Dave Hanks
