help with deleting duplicate lines
tnttrikes
Post by tnttrikes »
i need help fast !
i am trying to cut this for a gift and cant delete the duplicate lines.
if anyone can help fix this file
Thank you
Copp3r
Gorman Farms - oval
Post by Copp3r »
I had a quick work over your drawing. See if that does the trick. I sure hope so.
Best of Luck !
Copp3r / Roger
Re: help with deleting duplicate lines
I pulled it up and didn't find any double lines a couple of straight lines that weren't joined and I fixed them. Otherwise it opened fine for me. Called it Untitled- 2. Hope it helps.
Opps doesn't seem to have uploaded, here it is.
redneckgateart
Post by redneckgateart »
Your drawing seemed to have about 15 copies of the outer oval....here is a simplified version. I hope it helps.
Clark
gormanfarms.dxf
Chopper John
Post by Chopper John »
I gave it a quick clean and fixed what needed fixing, should be cut ready. Is this the look you were after?
Chopper John
Mad City Cycles, Inc.
tnttrikes
Post by tnttrikes »
Thank you all for the help!
Chopper John what did you do ??? it works!!!
Thank you
And to pipeliner for posting the tractor file Thank you
