Aluminum settings -for Hypertherm 1000
J&S
Post by J&S »
I have a large project where I need to cut several pieces out of .120 aluminum and I have know idea what settings to use. I have a hypertherm 1000 any help would be great.
Thank You
gary42095
Re: Aluminum settings
Post by gary42095 »
according to hypertherm chart for powermax 85 using 45 amp consumables i got this .120 comes out to 3/25" which i would guess using the hypertherm chart is kind of in between 3/32" and 1/16
hypertherm spec is for pmx85 is
1/16 .1 pierce delay 325ipm 136volt for best quality
3/32 .2 pierce delay 200ipm 136volt
my guess would be somewhere in between those on low amp comsumables increased feed speeds with higher amperage
65amp consumables in 1/16'' show feed speed at 365ipm 121 volts
my very very very uneducated assumption... im sure jim will let you know (and i can see how close i got) :?
teknition1
Post by teknition1 »
Use the cut charts in the operators manual.
Brad
Hypertherm 1000 owners manual.zip
(4.72 MiB) Downloaded 122 times
Post by jimcolt »
This.....right out of the Powermax1000 operators manual....should help!
40 amp shielded consumables
Shield: 120930
Retaining Cap: 120928
Nozzle: 120932
Electrode: 120926
Swirl ring: 120925
Aluminum specs, 1/8"
Pierce height: .08"
Pierce delay time: .5 seconds
Cut height: .06"
Arc voltage: 149 (start at this voltage and then adjust voltage until torch height is at .06")
Optimal cut speed: 133 inches per minute
Your cuts will look like these on aluminum:
Jim Colt
J&S wrote:I have a large project where I need to cut several pieces out of .120 aluminum and I have know idea what settings to use. I have a hypertherm 1000 any help would be great.
Thank You
J&S
Post by J&S »
Thanks to all of you for your help and I have downloaded a manual mine has seen better days
