I HAVE HPR 260 XD USING 30 AMPS ON 14 GA PLATE, ON 5 X 10, 3000 SERIES MULTICAM,MULTICAM GUYS ARE BUSY AND WAS LOOKING FOR MAYBE A QUICK ANSWER ,IS THERE A PARAMETER I CAN SET TO KEEP TORCH FROM NOSE DIVING ,ACTIVATING BREAK AWAY SENSOR AND STOPPING CYCLE?
PLEASE THANKS
DEAN
NOSE DIVING TORCH ATTN ;JIM COLT PLEASE
Re: NOSE DIVING TORCH ATTN ;JIM COLT PLEASE
JIM
I SHOULD HAVE NOTED THAT IT WAS ON LEAD OUT OF PART
THANKS
DEAN
THANKS
DEAN
Diving during the cut is a function of the torch height control.....yes there will be a setting that will minimize or eliminate this. The height control on the Multicam machines is built by Multicam....so this will have to be answered by them.
jim Colt
jim Colt
MACHINEMMAN wrote:I HAVE HPR 260 XD USING 30 AMPS ON 14 GA PLATE, ON 5 X 10, 3000 SERIES MULTICAM,MULTICAM GUYS ARE BUSY AND WAS LOOKING FOR MAYBE A QUICK ANSWER ,IS THERE A PARAMETER I CAN SET TO KEEP TORCH FROM NOSE DIVING ,ACTIVATING BREAK AWAY SENSOR AND STOPPING CYCLE?
PLEASE THANKS
DEAN
JIM
I HAVE PRONEST 2012 ,A HYPERTHERM PRODUCT . I FOUND IN SETTINGS ,CNC OUTPUT, A HEIGHT CONTROL DISABLE ON LEAD OUT,THAT WORKED
THANKS ANYWAY
DEAN
THANKS ANYWAY
DEAN
- 4R8
So what you're saying is the Multicam guys have poor support and leave a bloke to fend for himself after the sale is made?
That should've been diagnosed with a 5 min convo on the phone?
There are also cnc control outputs that have to be set correctly in order to eliminate diving....these will freeze height corrections during corner slowdowns.
In your original post you did not mention that you were using the Pronest 2012 CAM software.....most Multicam machines use software from Shop Data Systems.
Sounds like you have it sorted out.
MACHINEMMAN wrote:JIM
THANKS ANYWAY
DEAN
