Duck Hunting Time
trucks1948
Duck Hunting Time
Post by trucks1948 »
Time to go hunting again.jim
spinneybent
Re: Duck Hunting Time
Post by spinneybent »
Love the flying ducks! Are you gonna share this dxf of these?
trucks1948
I'll see if i can find it.Jim
trucks1948
heres the ducks
mallard.dxf
(305.04 KiB) Downloaded 687 times
Eagle Mtn Metal Works
Nice file trucks1948. Here is one that I have just cut at about a 12x12 . need to do some work to the duck. This is not even close as good as yours is but I am a newbe at this If I can get it uploaded. Thanks. Rod in AZ.
Last edited by Eagle Mtn Metal Works on Sat Nov 06, 2010 12:09 pm, edited 3 times in total.
Rod S in AZ
trucks1948
i can't do the pcm could someone make it dxf?Thanks Jim
dreamer
Post by dreamer »
here you go............Harold
seating duck.dxf
(125.74 KiB) Downloaded 463 times
Post by BrianMick »
pic
Hey Jim I cut the main part of this file ( Duck in frame )and the lower part of the duck's bill will cut out ok if you don't cut it smaller then a 10 x10. I was doing some editing on Sunday on this file and by mastake I deleated the hole file and I tought that I had lost the hole file. :( I did not relise that the (Setting Ducks) file, that I posted had the Duck on the pond, in this file. I had to download it again so I could edit and finish the Duck on the pond part. :lol: Nice work on the Mallards. :)
Rod S in AZ
Rem300wm
Post by Rem300wm »
Hello to all
trucks1948 Can You tell Me Where to get the Hunter and dog file ? I Like it very much and will like to cut it for a friend of mine.
Thanks for the help.
Rem
trucks1948
it should be on here if you do a search.If you can't find it PM me and ill see if i can.Jim
Rem300wm
Post by Rem300wm »
Hello to all
Jim I have found the file .
Thank You for Your help.
Rem
Zephrant
Post by Zephrant »
Gotta say thanks for the Ducks- That is the first file that I could literately one-click in PlasmaCAM, and it pathed every part of it. I had to scale it down a touch to fit on the metal I have on hand, but I'm heading out to cut it now. Wish me luck-
