Can vcarve dxf files work with a plasmacam that doesn't have advanced design software? I have the router attachment.
Or more specifically, can the generated dxf file work with the router attachment for a 2D project?
I want to cut out some letters using the router attachment for my plasma cam but I don't have advanced design or the 3D software upgrade... 2K$$ upgrade... don't get me started... I'm not trying to do any 3d work right now. Just straight cuts at a onto a board attached to a sacrificial one.
Re: Can vcarve dxf files work with a plasmacam that doesn't have advanced design software?
Yes - you can save your dxf file from VCarve Pro and import to Design Edge for creating cut paths. And yes - the generated dxf file will work with your router attachment for a 2D project. The instructions for setting up the router attachment are contained in the Video Manual. I have included them below for convenience.
cfo64nc - we have not heard back from you. Was any of this information helpful to you or do you still have more questions about using the software? If so please let us know and we will be happy to try to answer any more questions you may have.
- 1MORECUT
John - that's what I meant - although I didn't say it explicitly. He does not need advanced design and he does not need the 3d upgrade to import and cut a 2d file. I know you have a few videos showing your Plasmacam router making some wood parts. Perhaps share them here so the OP can get a better idea of the process.
- Joe Jones
I have so much more fun using a router on my PlasmaCam table than I do using a plasma torch. The routing process is cleaner. no smoke or fumes. A simple air blower for the dust. AND you can heat or cool your shop when using a router, because you are not pumping air OUT of your shop at 1,500 cubic feet per minute!
Franklin, KY., USA
Samson 510 & 4x4
CreatBot D600 PRO 3D Printer
16 Lasers
FREE DesignEdge Training!
Samson 510 & 4x4
16 Lasers
