cutting small pieces of stainless steel
ctorres3120
Post by ctorres3120 »
cutting small pieces of stainless steel and engraving them with a mini Milling machine.
Carlos
CorelDrawX4
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
Hypertherm PowerMax 1250
http://www.facebook.com/ctorresp?ref=tn_tnmn
dustywill
Re: cutting small pieces of stainless steel
Post by dustywill »
I love the rings idea. Cool stuff.
Precision Plasma 4x8 v-rail
C&CNC dragon cut 620
Hypertherm Powermax 45
Auburn, AL
www.facebook.com/decorativemetalworks
This is a good example why some of us are metal workers and others are artist!
Very nice!!
Question what size bit do you use and what RPM and depth of cuts and how many passes do you use?
Thanks Tom
DXF
Post by DXF »
Awesome! How did you polish the pieces to a mirror finish?
Dave Hanks
ctorres3120
DXF wrote:Awesome! How did you polish the pieces to a mirror finish?
Dave Hanks
Greetings Dave!!
sandpaper to prevent small parts in use 8/S/Fine Silicon Carbide Convolute Deburring Wheel , purchased in Ebay
Second, I use the polishing paste # 5 and # 6
in larger pieces use sand from 220-1500 and 8/S/Fine Silicon Carbide Convolute Deburring Wheel +polishing paste # 2 and # 1
Carlos
CorelDrawX4
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
ctorres3120
acourtjester wrote:This is a good example why some of us are metal workers and others are artist!
Very nice!!
Thanks Tom
Carbide 0.1mm 30 Degree Engraving Bits CNC Router Tool V-shape,used DeWALT DW887 Heavy Duty 1-1/2" Electric Straight Die Grinder Grinding Tool 25.000RPM,but it need not be so RPM, I can not control,I give 3 passes of 5 milecimas.
CorelDrawX4
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
hooked
Post by hooked »
ctorres3120 wrote:cutting small pieces of stainless steel and engraving them with a mini Milling machine.
Carlos
Carlos, the engraver your using? its not listed in ur list of toys to play with? what kind is it and what size is it? Carlos, ur detailed work is super nice! well thought out! Kyle
Thank for the cutter info
Also interesting using a grinder not a router for spinning the bit "smart"
Always nice to see new ideas being posts goes back to the saying "none of us know it all "
ctorres3120
Carlos
the pieces are cut into the table of the plasma, after cleaning the edges with the grinder, put it in the milling mini this photo for me to fabricate the plate already has cavities and step engrave the figures, the miling mini is 24 "x24"
CorelDrawX4
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
wilber
Post by wilber »
I have not tried metal yet on my CNC router. What feed rate were you using?
Post by tnbndr »
Very nice work!
Do you only offer one size of ring? or build them in various sizes (finger sizes).
muzza
Post by muzza »
Great looking work Carlos, you obviously enjoy working and polishing stainless much more than me.
Murray
ctorres3120
wilber wrote:I have not tried metal yet on my CNC router. What feed rate were you using?
I engrave 6 IPM
Carlos
CorelDrawX4
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
ctorres3120
tnbndr wrote:Very nice work!
whether different pieces of short length
? diameter x 3.14 I use to find the length of the piece and know the circumference of the ring.
Carlos
CorelDrawX4
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
Buzzard Gut
Post by Buzzard Gut »
WOW! that's some awesome work Carlos !
Bob Greer
The older I get, The better it was!
Sampson Jones
Post by Sampson Jones »
I guess you mill a slot in the material to hold the part down ? Does anything clamp down on the part? What is the material you slot out made of ? What kind of machine is that ? Thanks
CandCNC electronics
Hypertherm powermax 65
Command Lineux
Super z 2
Inkscape and corel draw
ctorres3120
Sampson Jones,'ll answer your questions soon
Carlos
CorelDrawX4
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
ctorres3120
more :D
CorelDrawX4
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
michmetalman
Post by michmetalman »
Awesome stuff!
ctorres3120
Sampson Jones wrote:I guess you mill a slot in the material to hold the part down ? Does anything clamp down on the part? What is the material you slot out made of ? What kind of machine is that ? Thanks
The material is 0.0625 "or less, the mini milling is homemade, here's some pictures of how I hold the pieces
Carlos.
CorelDrawX4
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
Craig
Post by Craig »
Beautiful work Carlos you are a talented artist. I like the Machete earrings. Craig Johnson
Craig Johnson
Metal Man
Post by Metal Man »
Very cool
Metal Man
Post by Metal Man »
How do you wrap it
