laser cross hair for plasma table
kkroger
Re: laser cross hair for plasma table
Post by kkroger »
DXF of Altered Long Bracket to accommodate Tom's HF Laser units...
Jeff M
Post by Jeff M »
Nice file, THANKS !!!
_Ogre
Post by _Ogre »
nice. one thread for many bracket ideas :mrgreen:
LakeCruiser
Post by LakeCruiser »
All of them look good. Great job guys!
Homemade 36X36 table
Can go from Plasma to Router in 10 Minutes
American Modified Chinese Controller
Proma Electronics THC
Cambam and Mach3
Longevity Forcecut 40D
Miller 211 MIG Welder
kkroger
Post by kkroger »
This one should be made with a router from Half Inch Aluminum or Acrylic, will fit the HF Lasers use a threaded hole and set screw to secure them, a set screw on the Torch, and this one mounts the cam for the scanner too.
Specifically the Supereyes B008 but you can adjust the hole to fit what you wish.
cutting$burning
Post by cutting$burning »
acourtjester wrote:Here is a laser cross hair I made for my table I have a Hypertherm 65 Machine torch on my DIY table.
These are HF lasers about $5. each no wiring needed, worked for finding the edge of the metal too.
Single screw holds it on easy to install and remove.
Just wanted to say thanks to Tom for sharing this awsome idea, and a extra THANK YOU BIG TIME for making and shipping me one of these. D
_Ogre
Post by _Ogre »
kkroger wrote:This one should be made with a router from Half Inch Aluminum or Acrylic, will fit the HF Lasers use a threaded hole and set screw to secure them, a set screw on the Torch, and this one mounts the cam for the scanner too.
you want the lasers mounted at 90* to each other from the torch center
less than 90* (or more than 90*) and the lasers will only be right at one height
simple geometry :mrgreen:
kkroger
Post by kkroger »
According to CAD the holes are on a 90 degree radial from the 1 3/8 hole.
But thanks for the instructions.... :geek:
Nacs Fab
Post by Nacs Fab »
I used Ogre's mount and modified it for my use. Image I am curious how you will get your laser to point at the torch if the holes are routed without an angle. I the reason for the oblong holes in Ogre's design is so that you can aim the laser at the torch.
G540 with LCTHC by candcnc
all built... by me...
kkroger
Post by kkroger »
Read, Read again...
The Lasers are the Harbor Freight Lasers that Tom put up (Acourtjester) they are basically round, there is not "Line" to deal with.
the lens rotates to align the laser line.
the others can be done the same way then use a set screw to fix them in place.
it ain't rocket surgery!
_Ogre
Post by _Ogre »
kkroger wrote:According to CAD the holes are on a 90 degree radial from the 1 3/8 hole.
my bad, i quickly held the corner of a piece of paper up to my screen, it's definitely an optical illusion :D
@nacsfab: nice work, did you use the pc power supply too?.
i have a longer torch and have the bracket up quite a ways, that close to the material i can't see the cross hairs
if you turn the cross hairs you can use the lines to square your material too
anyone else have problems with water splashing up and making the laser line an inch wide? :mrgreen:
kkroger
Post by kkroger »
Not yet, don't have them on for anything but alignment and since I am still using the hand torch (don't have a GOOD)
Plasma Cutter yet, the spacing on that bracket is similar to your "Long" style... So that should work, the Harbor Freight lasers are a little different.
toddler
Post by toddler »
Great Files! Thanks!
radicalrescue
Post by radicalrescue »
thanks for the file sweet..cut one last night welded it up .. :shock: .an opps bent it the wrong way ,it hits my gantry well going to try it again
radicalrescue
thanks for that file nice work..cut one but opps..u have to look at the what way ur bending it ..one way it hit my gantry on my tracker 4x8 table thanks again...
Greolt
Post by Greolt »
Another option is to get a cross hair laser. One that produces a cross instead of a single line.
Mount it beside the torch aimed vertically down. This is a known and constant offset from the torch centre.
Make an on-screen button (in Mach3) that moves X and Y axis to take up the position of the cross hair.
This way of doing it is used often in CNC routers and the like. Works well.
Much simpler and more compact mounting method.
AVART
Post by AVART »
Great work thanks for sharing.
whiskeymike
Post by whiskeymike »
Anyone seen these lasers at HF recently? I can't find them on the website. Any other lasers that are recommended?
exapprentice
Post by exapprentice »
Hi everyone
only a suggestion, but I think they are far cheaper :?:
I intend to use a "Bore / cartridge laser" :idea: you can find them on that well known site (or should that be sight)
they run of 3x batteries so no wiring 8-) , havent seen any with cross hairs but a 1.5mm dot should do the job ;)
Best Regards to all
Exapprentice :D
(Pete)
Bobcat320
Post by Bobcat320 »
exapprentice wrote:Hi everyone
This is what I bought form my table, just haven't made the bracket & hooked it all up yet. And I found the 1.5mm cross hair laser...
PlasmaCam DHC2
Hyperthem PM65
Edwards 25T Ironworker
_Ogre
Post by _Ogre »
you don't want a cross hair laser, but 2 line lasers similar to what acourtjester posted
mounted at 90* to each other the line laser makes a cross that will work at any z-axis height
any angle other than 90* will only work at one z-axis height
while the harbor fright line lasers will work, they will also suck up batteries
having the pc power supply makes it easy to turn on/off with the x-box controller
the m30 command at the end of every sheetcam g-code turns off the power supply
the 3-5v line lasers cost $2 on ebay, buy 5 or 10 in case they burn out :mrgreen:
we went thru 5 quickly but have not burned up any in 5 mths
after lining up the line lasers and focusing the line we lock them in with super glue
this is the type of laser line you want, they have free shipping from china for $1.99
for that price buy 5 just in case (we bought 10) :mrgreen:
http://www.ebay.com/itm/Red-Line-Laser- ... SwjVVVgRuu
you do not want this cross hair laser
Bobcat320
Post by Bobcat320 »
Coool... I think I bought the right one!
PlasmaCam DHC2
Hyperthem PM65
exapprentice
Any body in the UK found a good supply for this :?:
How long do the laser units you use last, do they get covered in the proverbial crap from the cut
Has anyone run a laser pointer using the power from a USB port :o
Best Regards to all
Exapprentice :D
(Pete)
exapprentice
on reflection and thinking about it after asking the question
probably not a good idea to have wires right from the cutting end going back to the PC at the USB end :roll:
PRETTY SURE THAT WOULD TRACK BACK SOME SORT OF INTERFERENCE AND MAKE THINGS JUMP :idea:
Maybe I will just stick with the battery powered option and avoid any chance of a hiccup :?
Best Regards to all
Exapprentice :D
(Pete)
