3/16 dragon with wings
This is a pic of the large dragon I make. I have the file in pcm if anyone is interested
- HammerDownJustin
Re: 3/16 dragon with wings
That is very nice
Miller 251 Mig
Miller 251 Mig
- CNCCAJUN
Any chance you can post it as a DFX file?
That is really a fine looking dragon . . .
Thanks in advance,
Thanks in advance,
Dynatorch 4X4 XLS
PowerMAX 85
Baton Rouge, Louisiana
Dynatorch 4X4 XLS
PowerMAX 85
my software doesnt have an export as dxf option. sorry
my software doesnt have an export as dxf option. sorry . Ill post it as pcm ..maybe someone will load it and put it back here as dxf
Heres the DXF, HarryMorley what is your kerf offset set at?
Few problems in life can't be solved with the generous application of a cutting torch and a taco truck.... or something like that.....
- Craig
Very nice, thanks for the share.
kerf offset .067 .. dont really know if thats correct but it works well
- CNCCAJUN
Downloaded the DXF . . .
Why are most of the parts drawn with double lines?
Steve in Louisiana
Steve in Louisiana
Dynatorch 4X4 XLS
PowerMAX 85
Dynatorch 4X4 XLS
PowerMAX 85
could it be youre seeing cut paths too
- CNCCAJUN
I very well be . . . I am trying to learn as much as I can. . . .harrymorley wrote:could it be youre seeing cut paths too
When open I see 99% of the parts or double line, like offset looks in AutoCAD . . .
Will not have a table ordered for about a month.
Dynatorch 4X4 XLS
PowerMAX 85
Dynatorch 4X4 XLS
PowerMAX 85
Hope you don't mind Harry but I cleaned up your original file to get rid of the cut paths. Hopefully everyone won't be seeing double now
Jason Lyon
PlasmaCAM DHC2
Advanced DesignEdge
Hypertherm Powermax 1000
Everlast PowerMTS 251si
Torturing metal since 2014
PlasmaCAM DHC2
Advanced DesignEdge
Re: 3/16 dragon with wings..asssembly insts
here are the assembly instructions for the 3/16 dragon.
- CNCCAJUN
Thanksharrymorley wrote:here are the assembly instructions for the 3/16 dragon.
Dynatorch 4X4 XLS
PowerMAX 85
Dynatorch 4X4 XLS
PowerMAX 85
- MetalheadRK
Thanks for the file and assembly instructions
Solomanb
Solomanb
thank you for the file
This is really fantastic. Thanks for sharing
Wow. Great work.
Brew Worx.
Blue Frog Metal Works
Chicagoland
Arclight 4800
Hypertherm 45
4 inch tube cutter
Mach 3, SheetCAM, Solid Edge 2D, Solid Works 3D, CREO, Inkscape, and a few cobb webs
Chicagoland
Arclight 4800
Hypertherm 45
4 inch tube cutter
Now is there a quick way to reduce the slots for say 14g or 11g ?
cheers I must give that a try
This look incredible. Thanks to everyone who took the time to make this a great project to try!!
Wow. What a great file. Thanks for sharing. The kids will like this.
Picture shows dragon with wings. PDF no wings. Is there another PDF or is it easy to apply wings?
