Skid loader blank mounting plate
Scratch
Post by Scratch »
I'm looking to add an attachment to our skid loader and am wondering if anyone has a file for a generic mounting plate to go on one...?
BIGJIM
Re: Skid loader blank mounting plate
Post by BIGJIM »
The 3/8" bar will weld across the top of the plate angled away from it so your skidloader can pick it up, I can't remember the angle off hand, but if you look at one of you attachments you should be able to figure it out. This plate works well, I make it for a couple different clients for various applications.
QUICKTACHPLATEnew.dxf
motoguy
Post by motoguy »
Is this a generic quick release plate that should work across multiple brands? I have a friend that needs one, as his cobbled-together version keeps coming apart. I believe he said they're all the same pattern, but I don't know if that is accurate or not.
I am not sure but I would guess that you would be able to make this work on just about anything with a little modification. Certainly a great start. Love seeing these old threads dug up
