cutting small pieces of stainless steel
- ctorres3120
cutting small pieces of stainless steel and engraving them with a mini Milling machine.
Carlos
Carlos
CorelDrawX4
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
Hypertherm PowerMax 1250
http://www.facebook.com/ctorresp?ref=tn_tnmn
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
Re: cutting small pieces of stainless steel
I love the rings idea. Cool stuff.
Precision Plasma 4x8 v-rail
C&CNC dragon cut 620
Hypertherm Powermax 45
Auburn, AL
www.facebook.com/decorativemetalworks
Auburn, AL
This is a good example why some of us are metal workers and others are artist!
Very nice!!
Question what size bit do you use and what RPM and depth of cuts and how many passes do you use?
Thanks Tom
Very nice!!
Thanks Tom
Awesome! How did you polish the pieces to a mirror finish?
Dave Hanks
Dave Hanks
- ctorres3120
Greetings Dave!!DXF wrote:Awesome! How did you polish the pieces to a mirror finish?
Dave Hanks
sandpaper to prevent small parts in use 8/S/Fine Silicon Carbide Convolute Deburring Wheel , purchased in Ebay
Second, I use the polishing paste # 5 and # 6
in larger pieces use sand from 220-1500 and 8/S/Fine Silicon Carbide Convolute Deburring Wheel +polishing paste # 2 and # 1
Carlos
CorelDrawX4
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
- ctorres3120
Carbide 0.1mm 30 Degree Engraving Bits CNC Router Tool V-shape,used DeWALT DW887 Heavy Duty 1-1/2" Electric Straight Die Grinder Grinding Tool 25.000RPM,but it need not be so RPM, I can not control,I give 3 passes of 5 milecimas.acourtjester wrote:This is a good example why some of us are metal workers and others are artist!
Very nice!!
Thanks Tom
CorelDrawX4
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
Carlos, the engraver your using? its not listed in ur list of toys to play with? what kind is it and what size is it? Carlos, ur detailed work is super nice! well thought out! Kylectorres3120 wrote:cutting small pieces of stainless steel and engraving them with a mini Milling machine.
Carlos
Thank for the cutter info
Also interesting using a grinder not a router for spinning the bit "smart"
Always nice to see new ideas being posts goes back to the saying "none of us know it all "
- ctorres3120
the pieces are cut into the table of the plasma, after cleaning the edges with the grinder, put it in the milling mini this photo for me to fabricate the plate already has cavities and step engrave the figures, the miling mini is 24 "x24"hooked wrote:Carlos, the engraver your using? its not listed in ur list of toys to play with? what kind is it and what size is it? Carlos, ur detailed work is super nice! well thought out! Kylectorres3120 wrote:cutting small pieces of stainless steel and engraving them with a mini Milling machine.
Carlos
CorelDrawX4
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
- wilber
I have not tried metal yet on my CNC router. What feed rate were you using?
*** DynaTorch Super B 4x8 with a Hypertherm Powermax 65****
- tnbndr
Very nice work!
Do you only offer one size of ring? or build them in various sizes (finger sizes).
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
Great looking work Carlos, you obviously enjoy working and polishing stainless much more than me.
Murray
Murray
- ctorres3120
I engrave 6 IPMwilber wrote:I have not tried metal yet on my CNC router. What feed rate were you using?
Carlos
CorelDrawX4
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
- ctorres3120
tnbndr wrote:Very nice work!
whether different pieces of short length
? diameter x 3.14 I use to find the length of the piece and know the circumference of the ring.
Carlos
CorelDrawX4
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
- Buzzard Gut
WOW! that's some awesome work Carlos !
Bob Greer
Bob Greer
The older I get, The better it was!
- Sampson Jones
I guess you mill a slot in the material to hold the part down ? Does anything clamp down on the part? What is the material you slot out made of ? What kind of machine is that ? Thanks
CandCNC electronics
Hypertherm powermax 65
Command Lineux
Super z 2
Inkscape and corel draw
CandCNC electronics
Command Lineux
Super z 2
- ctorres3120
Sampson Jones,'ll answer your questions soon
Carlos
Carlos
CorelDrawX4
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
- ctorres3120
more
CorelDrawX4
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
Awesome stuff!
- ctorres3120
The material is 0.0625 "or less, the mini milling is homemade, here's some pictures of how I hold the piecesSampson Jones wrote:I guess you mill a slot in the material to hold the part down ? Does anything clamp down on the part? What is the material you slot out made of ? What kind of machine is that ? Thanks
Carlos.
CorelDrawX4
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
MasterCam
SheetCam
Mach3
PlasmaCNC 6x6 Table
- Craig
Beautiful work Carlos you are a talented artist. I like the Machete earrings. Craig Johnson
Craig Johnson
How do you wrap it
