Plate Marker questions
- WyoGreen
I've been looking at some of the Plate Marker art projects the last couple of weeks, and it looks like something I'd like to set up. I have a few questions. I've been watching a few YouTube videos of Plate markers, and it appears there are basically two ways of mounting the scribe. 1 way appears that the scribe assembly is mounted to the gantry z axis carriage, and does not move up and down with the torch mount. The 2nd way seems to mount the scribe assembly to the torch mount, and moves up and down with the z axis. I can see moving the scribe up and down on the z axis so you can set it the same height above the plate, no matter the plate thickness. The other way of mounting, I'm not sure of what the advantages to that are, but there must be a reason.
So can someone with a plate marker discuss how they mounted their scribe, and why?
Thanks, Steve
Thanks, Steve
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
- _Ogre
Re: Plate Marker questions
check out my $100 plate marker set up http://www.plasmaspider.com/viewtopic.p ... 130#p73130
our bulltear table has tall clearance over the table for various fixtures and a rotary head for tube
the bulltear table has ~9'' of travel in the z-axis, and the gantry sits 12'' above the table
that would make impossible to mount the head on the gantry head, mine is mounted on the z-axis
i still needed a long air slide to keep the engraver clear of fixtures and get it down to the material
we have a mag mount for the torch head, the plate marker mounts behind the mag mount
also have a video on youtube https://www.youtube.com/watch?v=5O8rjZ_ ... e=youtu.be
an ogre smiley how cool!
I have mine hooked to the Z axis I don't have the travel that Ogre has because I don't use the plate marker and torch at the same time I have about 2" up/down cylinder to move the plate marker. If I'm doing a small plate I put plywood on the water table clamp the plate to it. The Z axis gives placement of the scribe tip to about 1-1/2" above the metal and the cylinder make the contact to the metal it only takes about 5 PSI but 90 PSI for the scribe.
- WyoGreen
Thanks guys, I appreciate the feedback. One thing I was wondering about is if the single cylinder rotates any as it goes up and down. After looking at acourtjester's setup I'd say the answer is yes, as it appears he has a rail set up to keep the scribe from turning. I'm also concerned about adding weight to the Z axis, and acourtjester's mount looks pretty lightweight.
All good things to think about as I progress on the design and fabrication phase. I'm sure I'll have other questions over the coming weeks, so again, Thanks a Lot.
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
the one I built (and now belongs to OldSarge) is on the Z axis and floats above the tip level of the torch. When activated by M command the cylinder drives it down below the torch level to engrave. Engrave first then cut.
plain ol Bill
Hypertherm 1250
Duramax machine torch
Corel Draw X6
Mach3
5 x 10 self built table
Lots of ineptitude
Hypertherm 1250
Corel Draw X6
Mach3
Lots of ineptitude
The cylinder is only for up/down movement the rail keeps the scribe from wondering. Its just like the torch you want to control its position for accuracy. You could use round linear guides but you would need two in parallel as you can see in Ogre's video.
- _Ogre
i use a numatics linear slide, 2 guide bars and a single cylinder
new it would be over $500 (also why the kits are pricey), i found this one on ebay for $29
http://www.numatics.com/common/PDF/shseries.pdf
if your going to make your own i'd base it on what you can find cheap on ebay
search on ebay for: air slide, linear air slide, linear slide or any version of that
most are new stock left over from machine builds, though used would work also
- WyoGreen
Now that I've got my plate marker working, it's time for pictures and stuff.
Here's a shot of the finished Plate marker from the front and side: And here's the air control setup. What I ended up doing is getting an air valve from the surplus center, which while cheap, was 24 Volt DC, so I made up a power supply for it using a 24 Volt transformer and a bridge rectifier I had laying around from another project. I decided to run the air at 120 psi into the valve, splitting it to 2 air regulators on the normally closed side of the valve, one regulator for the down pressure on the air cylinder, and one to the air scribe (a CP 9361). The normally open side of the valve went to the up pressure on the air cylinder. The air cylinder is a dual rod cylinder I picked up on Ebay. The scribe came from a tool supplier for a decent price.(relative to the cost of the table anyway)
And then a shot of the scribe oiler, which I picked up from the Surplus Center. I took the filter off the end of the scribe hose and put it on the input to the oiler, so I wouldn't running oil thru the filter. I set the scribe up using this document, which was information I copied from various places on the internet. Again, thanks to everyone for your help on this project.
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
Thanks for the information,
Gary
Gary
Candcnc DHCTII Electronics
Sheetcam, Mach 3
Corel Draw 8, V Carve Pro
Miller CTS 280 Miller Mig
Sheetcam, Mach 3
- _Ogre
nice work wyogreen, the scribe adds a little versatility to the plasma table
i still haven't figured out how to turn off and raise the scribe without manually entering M09 before the last scribe command
otherwise it just drags the scribe across the material to home or drags the scribe along as it goes into plasma mode
on the plus end, i hit a yard sale last weekend. there on a shelf was an air scribe. i asked how much?
she said ''i don't even know what it is, give me a dollar'', i smiled and said ''how about $25''
i don't need anything else to keep me awake at night
- WyoGreen
Ogre, I would have loved to have found a $25 scribe. I did find a $69 dollar one, but when the guy checked it out before shipping, the stylus was broken, so he refunded my money. So I went ahead and bought a new one for $250. Close to your price, just an extra "0" on the end!
As far as the scribe raising up, I just use the newest sheetcam post from CandCNC, and set up the plate marker per the setup instructions for the post. Works like a dream, raises after every scribe'd part.
Good luck on yours, Steve
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
- _Ogre
ok, now you have my attention
where exactly are you downloading sheetcam post processors?
- captdick
My question too. I only want to change post processor for scribe. When I change post to Mp 1000 thc scribe it changes for all previous tools. Do I have to change post each time I want to use tool.
In other words how do you set up different post processors for different tools so you don't have to change then once set up---Thanks
I tried to run my old tools with the MP 1000 thc scribe post and the don't work.
My old tools work fine once changed back to MP 1000 thc.
I am using an older version of sheet can {3.0.16} I have been reluctant to upgrade to a newer version when all is working well.
I way I have my scribe set up is with a spring return cylinder it is internal to the cylinder. I use a 3 way solenoid which only applies air to the cylinder to go down then the solenoid allows the air to the cylinder to bleed back and the spring pushes the scribe up. I also create a tool for the scribe and choose it just like a plasma tool and use the same post processor for both. The scribe is an different operation then plasma. I did the same thing for the drag knife.
- WyoGreen
I download the latest post processors off the CandCNC web site. Right now Tom is working on a do everything post. The latest update loads a custom Mach3 screen, and updates the hub utility and the DTHC firmwares. The pdf with the update has instructions for setting up the Sheetcam tool-table for a plate marker, as well as for a plate marker center-punch, and a plasma drill tool to do peck center punches. It all works pretty well, although being new, it has a couple of minor bugs which Tom is working on. The newest post is DTHC-HYT-TAP_SoftPierce+Marker-rev12.scpost, which last time I looked hasn't been posted on the website. I imagine Tom is waiting to post it until he gets the last little bug fixed. There is a link to the post on the CandCNC Support Board.
I used a double-acting cylinder which uses air for the up and down. I set my up pressure to 90 psi (which is max cylinder pressure) to get a fast up, and my down pressure right now I'm running at 40 psi. I wanted to get my down pressure as light as possible to help protect the scribe stylus, but if I go too low, the cylinder is sometimes kinda slow going down. The scribe I run at 90 psi, which is just below it's max pressure. The CP-9361 has an adjustable air valve on the scribe which can also be adjusted to vary the speed of the scribe blows.
When I set my job up in Sheetcam, I put all the scribe and center-punch operations on one contour and run it first. If I have any plasma peck operations, they go on their own contour and run next. Then I do all the other plasma operations on their own contours. All these different operations are done using the same rev12 post, and just use different tools from the tool table.
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
- _Ogre
wyogreen... that doesn't answer my where did you download them question?
i've been all over the candcnc site and found nothing
though i did find the pipefit program, anxious to try it out
what speed do you scribe at?
i've tried 50 ipm and the corners aren't as sharp as when i slow down to 30 ipm
- WyoGreen
Good morning Ogre,
Sorry I wasn't more specific, I'll do better this time around. First off, here's a link to the CandCNC page. For some reason the downloads are on the manuals page. http://www.candcnc.com/manuals.htm. If you scroll down to the bottom of the page, you'll see a bunch of zip files. The bottom 2 probably contain the stuff you're interested in.
I'm running my scribe pretty slow till I'm sure I've got everything working the way I want. I'm only running 20ipm for now till I'm sure I've got my height where I want it, as I'm afraid higher speeds will put more sideways pressure on the stylus if it's too deep. What I've been noticing is that my water table slats are not perfectly level with my gantry, and a very little amount of height difference will make quite a lot of difference on the scribe. My initial thought was I'd put very little down pressure on the scribe and that would let the scribe float to make up for material warp, etc. But if I get down to 5 psi where I wanted, my air cylinder won't reliably come all the way down. I'm kicking around spring loading the air cylinder to see if that will help out my floating scribe idea.
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
- _Ogre
i was all over that site and never found that. thank youWyoGreen wrote:For some reason the downloads are on the manuals page.
i will try the new scribe post, i also cleaned out a lot of posts that i will never use
i found that the less speed and air pressure i have the better the scribe.
i have a 6 or 8 inch slide and have some play in the scribe.
i was setup to run 5psi on down pressure, my ebay 0-15psi gauge went bad
so no i adjust the down pressure to where i can easily pick up the scribe
i do not have my slide set to bottom out or rest on the stops
i could probably scribe corrugated roofing
when metering air you meter in (vs metering out on hydraulics)
i have metering valves on both ends of the slide, the valves meter in, free flow out
this way i can run full pressure up and control the speed with the valve, one less regulator
- WyoGreen
Ogre, your comments on air valves got me to thinking about my air regulator set up. I'll bet my down pressure problem is due to my up pressure regulator restricting the free flow of air from the air cylinder, thus slowing down the down direction. I'll have to go out to the shop and do a little testing.....
Thanks, Steve
Thanks, Steve
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
- _Ogre
my slide drops pretty fast for having 5 psi down pressure and i control the flow both up and down
youtube video here https://www.youtube.com/watch?v=5O8rjZ_3c_4
my slide is long, i'd like to have the z axis pick up .25'' instead of the slide working up and down
i really need to figure out how to edit post processors
most of my valves and fittings came from ebay seller mettle air
this is what i plugged into the air valve to get to 1/4'' air line
controlled flow one way, free flow the other
the fittings cost $2 the valves $6
how is that $8 air lubricator holding up?
is it adjustable or set on oil usage?
never been to that surplus center site
looks like a good one
- WyoGreen
Ogre, the oil lubricator is adjustable. The scribe instructions said 1 drop per minute. I had the oiler set at the mid point, and didn't really notice any drops when I started out. When the scribe started blowing little oil spots, I figured I might have it set a little high. So now I've got it set all the way down hoping to dry the oil out of the line a bit. If I remember right, you use an electric scribe, so you wouldn't get much out of an oiler! (though maybe it would loosen up those electrons some!)
Still haven't got the down pressure to 5 psi, but have managed to get down to 20 psi, so it's better, but not to the floating stage yet. I ended up drilling out the internal passages of the air cylinder to the same diameter as the air line, which made a big difference. I'm thinking maybe move the air regulator closer to the slide. I didn't want the extra weight on the gantry, but maybe the 12' of air line from the regulator to the cylinder is part of the problem. 5 psi probably doesn't flow all that fast in 1/4 inch air line.
If I don't have my z rapid clearance set the same as my z scribe offset, my z axis goes up and down with the scribe, only it lags a little bit, so the scribe has started moving before the z stops. Another reason to get the floating scribe working better. But maybe you could use that to your advantage on your setup. I suppose it depends on your machine setup and post processor.
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
- _Ogre
thanks, i'll try the surplus center oiler, i did find an air scibe at a yard sale a couple weekends ago
look in your tools setup in sheetcam; you can add a start delay to allow the air scribe to make contact
i had to add 1 sec delay to the scribe, it was moving before the scribe was fully down and engaged
i also have a cut height of .9'' so the torch does a touch off and moves up then over to the scriber offsets
i'm making a new scribe mount for the $25 air scribe, moving the scribe closer to the torch
right now i have a 6'' offset, if i try to scribe too close to the edge of a sheet the gantry runs off
oops, newb error
oops, newb error
- _Ogre
keeping this thread going instead of creating a new one
have my new controls setup for the air scribe; one 120v control valve, one air regulator and one airline in the track
down outlet on the valve has a T, straight thru for air scribe and speed valve for air slide down speed into regulator
my ebay 15psi gauge quit so i just set pressure to where i can easily lift the air slide
the new mount for the air scribe cantilevers over to the torch, this keeps the offsets tighter thus i can scribe closer to the edge
the design exaggerates any play in the slide, i'll need to move it back to the center of the air slide. bummer
- _Ogre
scriber post problem
i'm having issues with the scriber post; i've tried the MP1000-THC - with scriber post and the Mach3 THC with scriber post. both have the same issue, maybe someone can explain what i'm doing wrong. here is a simple 2 line, by 2 inches gcode .tap file with my comments in [brackets] my z offset is -5mm
N0010 (Filename: junk12.tap)
N0020 (Post processor: MP1000-THC - scriber.scpost) [scriber post shows as [edited] in sheetcam]
N0030 (Date: 13/12/2014)
N0040 G20 (Units: Inches)
N0050 G53 G90 G40
N0060 F1
N0070 (Part: scribe test)
N0080 (Process: No Offset, LINE, T100: Plate marker) [scriber is tool 100]
N0090 G00 X0.0000 Y0.5000
N0100 G28.1 Z0.12 F19.685
N0110 G92 Z0.0
N0120 G00 Z1.3200 [switch offset]
N0130 G92 Z0.0
N0140 G00 Z0.3937 [z axis has always gone to .3937 scribing but i don't know why]
N0150 Y3.4134
N0160 Z0.7031 [.9'' plasma rapid minus 5mm z axis offset][why 2 z axis moves?]
N0170 M08 [plate marker on]
N0180 G04 P1
N0190 G01 X2.0000 F50
N0200 M09 [plate marker off]
N0210 G04 P0.5
N0220 G00 X0.0000 Y2.9134
N0230 M08
N0240 G04 P1
N0250 G01 X2.0000
N0260 G00 Z0.1968 [z axis dives here, no idea why. scribe is still on]
[this is where i manually enter M09 to turn off scribe]
N0270 X0.0000 Y0.0000 Z0.3937
N0280 M05 M30
if i enter over -14mm in z axis offset line N0260 goes negative and torch crashes
i've been editing line N0260 G00 Z0.9 M09 to set z rapid height and turn off scriber
i use M07 for scriber output on, just yesterday figured out if i edit the scriber post and replace all M08 commands with M07 the post changes the gcode correctly.
for the M09 scriber off at the end of the scribing session, the post does not do this automatically in line N0260. it was suggested to edit the post
''For the M09 issue I checked and it is a bug in the post. Look for
function OnPenUp() and change this line:
if(tool > 99) then
to:
if(tool > 99 or toolClass == "MarkerTool") then''
i did that and still didn't work
ALSO... when starting scribing on any arc or circle the Z axis rises from what ever is on line N0160 to z axis rapid height of .9. the rise is even thru the arc or circle; small circle or large z rises evenly thru out the arc distance.
N0050 G53 G90 G40
N0060 F1
N0110 G92 Z0.0
N0130 G92 Z0.0
N0150 Y3.4134
N0180 G04 P1
N0210 G04 P0.5
N0230 M08
N0240 G04 P1
N0250 G01 X2.0000
N0280 M05 M30
if(tool > 99) then
to:
- _Ogre
more scriber post
here is a different post gcode with the same problem. note the z axis offset is -15mm on this one
N0010 (Filename: junk10.tap)
N0020 (Post processor: Mach3 THC with scriber.scpost)
N0030 (Date: 12/12/2014)
N0050 F1
N0060 G53 G90 G40
N0080 (Operation: No Offset, LINE, T100: Plate marker)
N0110 G92 Z0.0
N0120 G00 Z0.0520
N0130 G92 Z0.0
N0140 G00 Z0.3937 [again the Z0.3937 move. why?]
N0150 Y-2.8465
N0160 Z0.3094 [z rapid .9 minus 15mm z offset]
N0170 M08
N0180 G04 P1
N0190 G01 X2.0000 F50.0
N0200 M09
N0210 G04 P0.5
N0220 G00 X0.0000 Y-3.3465
N0230 M08
N0240 G04 P1
N0250 G01 X2.0000
N0260 G00 Z-0.1969 [notice torch height is negative herefrom the -15mm z offset] [this is where i would edit Z0.9 M09]
N0270 X0.0000 Y0.0000 Z0.3937 [again the Z0.3937 move. why?]
N0280 M05 M30
(z offset -15)
N0050 F1
N0060 G53 G90 G40
N0110 G92 Z0.0
N0120 G00 Z0.0520
N0130 G92 Z0.0
N0150 Y-2.8465
N0170 M08
N0180 G04 P1
N0200 M09
N0210 G04 P0.5
N0230 M08
N0240 G04 P1
N0250 G01 X2.0000
N0280 M05 M30
(z offset -15)
