I live in Corsicana and need help with my cnc plasma machine
I cant get it to cut and don't have a clue how to fix if someone can help text to (903) 467-9691 thanks
Help - PWM Spindle Speed set to minimum
- Gamelord
- 4.5 Star Member
Re: Help with cnc plasma machine
Sorry to hear you are having issues. Couple of things that will help get you on your way. If you can list what table you have, what software you are using, what plasma (cutter) you are using and what the actual problems are (the more detail the better) or even pictures, we can chime in and help get you going.
Torchmate CAD
Torchmate CAD
I have a 5x10 table running windows 7 mach3 I have tested wires with a volt meter they r good I'm getting this message
pwm bumped to minimum setting also when I unhook wires from snap on 60i plasma machine it works great when I hook it up it sends a pulse signal to cutter and its constant it goes on a second later off the on then off and I don't know how to fix it
What causes in Mach 3 to get PWM bumped to minimum setting
PWM is used for Spindle Speed. PWM is an option in MACH settings. Has noting to do with motion or plasma cutting. Its in the Spindle settings . It means the speed called in the gcode is less than the minimum you have set in the PWM spindle settings
Hayman,
I think I know what the problem is.
Go into Mach3 >> Config >> Ports & Pins >> Spindle Setup Tab
It will look like the attached.
I suspect that as I've shown, "PWM Control" is ticked.
If that is the case, untick "USE Spindle Motor Output" and it should work fine now.
