SVG always imports at the wrong size?
When importing a file that was designed to be, for example 36 in, it never imports at the intended size. It imports smaller at 28 in. I assume that this is a setting issue but I cannot figure out how to change it. When importing the DXF version of the same file into sheetcam it is the correct size. Thanks
Stephen W. Sparks RN,CRN
Creating Sparks Metal Worx
Arclight Dynamics Arc Pro 12000 5X10
Linux, Sheetcam, Inkscape, Solid Edge
MIllermatic 175
AHP Alphatig 200X
Kool Koat 3.0 DPW
"Ridin around having a big time!"
MIllermatic 175
AHP Alphatig 200X
Kool Koat 3.0 DPW
- WyoGreen
Re: SVG always imports at the wrong size?
Sometime in the last couple of days I was reading a post similar to this.
http://forum.sheetcam.com/viewtopic.php?t=6947
Not exactly like your problem, but the solution may get you going.
Precision Plasma gantry
HT-45 plasma cutter
Plate Marker
Router
Laser
HT-45 plasma cutter
Plate Marker
Router
Laser
Thanks WyoGreen but that refers to scaling while importing to sheetcam, my problem is when I import a predesigned file by someone else for example from this site, into inkscape is automatically scales it down and doesn't import at the original dimensions.
steve
steve
MIllermatic 175
AHP Alphatig 200X
Kool Koat 3.0 DPW
MIllermatic 175
AHP Alphatig 200X
Kool Koat 3.0 DPW
Here is how I do it in Inkscape, go to “document Properties” under the file menu and uncheck show pare border.
Then under default units click on in this changes the drawing screen to inch dimensions.
The save drawing in SVG for SheetCam then import in SheetCam and under scaling change to 1:1 ratio.
This will put the drawing to the size you have draw it in. I always position it in the lower left corner and then I can check the dimensions as shown in the attached screen shot
In reference to your last post if the dimensions are not correct from an unknown file from another member use my way to check the size and then import it again and change the scaling by changing the percent that will give you the correct size you want.
Thanks. I will give that a shot.
steve
steve
MIllermatic 175
AHP Alphatig 200X
Kool Koat 3.0 DPW
MIllermatic 175
AHP Alphatig 200X
Kool Koat 3.0 DPW
