need some help...friend needs the marker, I don't seem to be able to get the lettering to cut, or even be part of the dxf...this is in acad 16
thanks in advance...Sawdustcreek
lettering is goofy, can't make it part of the dxf
Re: lettering is goofy, can't make it part of the dxf
did the file not come thru?
- RobinHillMachine
I don't see a file.
- tnbndr
In Autocad you cannot use regular text, it doesn't export as a dxf. You have to use express tools, explode text command which will explode the text to lines and arcs. It will require some fixing up after that.
Or you can use an aftermarket text to dxf program such as Stencil Fonts, www.cadkas.com, and import the saved dxf into your drawing, explode and go from there.
LDR 4x8, Scribe, DTHCIV
Hypertherm PM45, Macair Dryer
Miller 215 MultiMatic
RW 390E Slip Roll (Powered)
AutoCAD, SheetCAM, Mach 3
http://ikescreations.com
Dennis,
Thank you...I had forgotten about that bunch of commands...will give it a try...seeing as I didn't get the file to load.....thanks again....don
