Need help from the macro experts
djreiswig
Post by djreiswig »
I have constructed a referencing macro to emulate the dual touch off feature in CommandCNC (as well as incorporating a few other features). It works great for the most part. I have 2 complementary macros that are run from the gcode to set the ohmic or touch leds depending on a setting in the tool in sheetcam. I also have an on screen button to cause the z axis to raise slightly higher to avoid collisions when doing a trial run (block delete feature in mach3) without the THC or torch operating. All this is run from the macro.
The macro works great, except if you try and feedhold while the reference is happening. I've had it crash my smoothstepper and freeze mach.
I think it might have something to do with the ismoving loops, but if I leave them out mach seems to skip over the code.
Any ideas on a way to fix this?
Code: Select all
OhmicLED = 1503 ' LED that indicates OFF
TouchLED = 1504 ' LED that indicates ON
RefFeed = 1120 ' Ref Feed from Settings
PlungeSafety = 1121 ' Plunge Safety from Settings
TrialZ = 1122 ' Trial Z from Settings
SwitchOffset = 1045 ' Switch Offset from Settings
If GetUserLED(OhmicLED) Then
  If IsActive(DIGITIZE) Then
    Message "Ohmic sensor jammed."
    MsgBox "Ohmic sensor jammed.  Clear and hit RUN to continue. ", 0 + 48 , "Clear Z Jam"
    Code ("M0")
  Else
    Code("G00 Z" & GetUserDRO(PlungeSafety) & " (Start probe touch-off)")
    While (IsMoving())
      'Sleep, so other threads can run while we’re waiting
      Sleep(100)
    Wend
    Code("G31 Z -3.937 F" & GetUserDRO(RefFeed))
    While (IsMoving())
      Sleep(100)
      If IsActive(ZHOME) Then 'ohmic missed
        Message "Ohmic sensor missed."
        If MsgBox ("Ohmic sensor missed.  Use touch?", 4 + 48, "Ohmic sensor missed.") = 6 Then
          Code("G92 Z0.0")
          While (IsMoving())
            Sleep(100)
          Wend
          Code("G00 Z" & GetUserDRO(SwitchOffset) & " (Switch offset lift)")
          While (IsMoving())
            Sleep(100)
          Wend
        Else
          Message ""
          code ("M0")
          End
        End If
      End If
    Wend
    Code("G92 Z0.0")
    While (IsMoving())
      Sleep(100)
    Wend
    If GetOEMLED(66) Then 'trial Z offset
      Code("G92 Z -" & GetUserDRO(TrialZ) & " (Trial Z offset)")
      While (IsMoving())
        Sleep(100)
      Wend
      Code ("G00 Z 0.0")
    End If
  End If
Else
  If GetUserLED(TouchLED) Then 'touch
      Message "Touch switch jammed."
      MsgBox "Touch switch jammed.  Clear and hit RUN to continue. ", 0 + 48, "Clear Z Jam"
      Code ("M0")
    Else
      Code("G28.1 Z" & GetUserDRO(PlungeSafety) & " (Start touch-off)")
      While (IsMoving())
        Sleep(100)
      Wend
      Code("G92 Z0.0")
      While (IsMoving())
        Sleep(100)
      Wend
      While (IsMoving())
        Sleep(100)
      Wend
      Code("G92 Z0.0")
      While (IsMoving())
        Sleep(100)
      Wend
        While (IsMoving())
          Sleep(100)
        Wend
        Code ("G00 Z 0.0")
      End If
    End If
  End If
End If
Return to “Mach3 & Mach4 CNC”
