Loosing gantry motor
fixitguy
Post by fixitguy »
My gantry motor quits working. I ordered a new motor and replaced it today. I cut 6 pieces and paused the unit for about 10-15 minutes, restart the cut and the motor is dead. All other motors work as they should. When I jog the motor the computer screen says its moving but its not. any help?
weldguy
Re: Loosing gantry motor
Post by weldguy »
That's a bummer. I am sure Tom will chime in with the solution as he always does but sounds like you may have a bad motor drive or bad luck.
TJS
Post by TJS »
Try posting over at the CandCNC site. They have a pretty good forum and updates as well.
tcaudle
Post by tcaudle »
Motors are about the last thing that fail and just won't turn. They are two coils, a big magnet and a couple of bearings. The best way to test is to take a known good motor off another axis and sub it to the axis in question. If it does the same thing its the driver or signals to the driver.
Return to “CandCNC Forum”
