Hi all
I have been having some issues with porous welds after cutting with My water table. I was having the issues when I was using GreenCut and have since switched to SterlingCool Plasmacut. I have not had to weld anything since switching to SterlingCool. I was lazy and didn’t grind the edge after cutting. Has anyone else ran into this issue. Thanks in advance.
Porous welds after cutting with GreenCut
Pete
Twisted Image Customs and Fabrication
Ontario Canada
Ontario Canada
Re: Porous welds after cutting with GreenCut
dirty metal is a prime cause of porous welds.
Pete - I would recommend cleaning the weld areas with lacquer thinner before welding to remove the cutting fluid residue.
