lead in help
lead in help
Can anyone point me in right direction for lead in offset. My lead in always cuts a little in to finish product. How can i adjust lead ins further away from Material i am Cutting? I use the outside offset but i always get a tiny half circle in my finish product.
Crossfire Plasma Table
Hypertherm pm 85 cpc rs-485
Miller 252 mig
Miller dynasty 280 Tic/stick
Metabo Mag drill
various Fab equipment
4x8 precision plasma table
G5 c and cnc controls
“ the Shop “ were it all happens
Miller 252 mig
Metabo Mag drill
- jmersereau
Re: lead in help
Are you running SheetCam? Are you using the ARC lead in?
Jim
Jim
PrimeWeld CUT60
Langmuir CrossFire Pro
Re: lead in help
Perhaps you could change the angle of the lead in to attempt to mitigate the marking of your edge. This may also depend on the geometry of your lead in - straight line, arc, etc. Maybe show us an example of the part and the program your are using.
Re: lead in help
i am using the arc lead in.the legth i set to .015 as per the video on arclights video. dont see were yo can change angle of lead in. I am using a brand new candcnc system the g5. In the programs it came with it seams there are way more settings on the screens then all the videos i have been watching for help.
Miller 252 mig
Metabo Mag drill
Miller 252 mig
Metabo Mag drill
Re: lead in help
A lead in that is .015" is very short, less than the kerf width and you will likely not even notice you had a lead in. Are you sure it's not supposed to be .150"? That would be the minimum length I would use.
Re: lead in help
That might help i will try that . Thanks i was thinking to mkae that longer just didnt know.
Miller 252 mig
Metabo Mag drill
Miller 252 mig
Metabo Mag drill
