Hi. My name is Salvador Rudas
I have Powermax 1000 g3 Series and i need know if this work with 220VAC 1 phase. the power cord have 4 wires, black, red, white and green but no have the connector.
can you help with diagram for connection.
in my country have 220AC mono phase (Line1, Line2,Neutral and Ground)
The specs machine have this
200 – 600 V, 1/3-PH, 50 - 60 Hz, CSA
230 – 400 V, 3-PH, 50 - 60 Hz, CE
Thanks a Lot.
Powermax 1000 G3 Series
Re: Powermax 1000 G3 Series
Attached is the operator manual for your machine. Power supply hookup can be found on pages 31-33 which will get you set up. Good luck and let us know how it works out.
