bike badge jpeg to dxf stl or svg help
mcmental
Post by mcmental »
good evening ive been given a task by a friend to try produce a few items for him, first to plasma out the emblem but also to then 3d print it to replace his lost badge off the motorcycle, unfortunately i only have 2 photos of the badge in different colours.
if you look on the picture with the Red R you can see the gold lettering is slightly raised by 1mm from the black background, the gold on the R is 2mm raised from the black and the red inside the R is 1mm from the black if that makes sense?
ROKCRLER
Re: bike badge jpeg to dxf stl or svg help
Post by ROKCRLER »
Depending on the size to be cut, the gold outline around the R will be super thin.
Here's my take on it.
It'll have to be a 3 layer with the red R at the top, or 2 with different paint/powered
4x8 Dynatorch
PM85
~Mo~
mcmental
Post by mcmental »
ROKCRLER wrote: Sat Sep 10, 2022 1:56 pm Depending on the size to be cut, the gold outline around the R will be super thin.
Thank you for that, how do you do this please?
ROKCRLER
Post by ROKCRLER »
I'll do a video today and show you how i did this.
It was done in Inkscape
4x8 Dynatorch
PM85
~Mo~
I think this one requires a manual trace as opposed to auto trace. There is a slight problem doing this since there is some parallax introduced from your photo of what I assume is a decal. Here is what I have come up with using Inkscape to manually trace.
1000R - from manual trace.svg
1000R - from manual trace.dxf
Here are some of my steps.
mcmental wrote: Sat Sep 10, 2022 12:16 pm good evening ive been given a task by a friend to try produce a few items for him, first to plasma out the emblem but also to then 3d print it to replace his lost badge off the motorcycle, unfortunately i only have 2 photos of the badge in different colours.
I think that Rokcrler will make a nice video showing you the actual steps he used. I will be curious to see if he started with an auto trace or manually traced your photo. You have not said what the overall size of the part is. Once you have specified this and decided on the vector file you wish to use, I will show you how to use Fusion 360 to create a solid model for 3D printing.
Joe Jones
Post by Joe Jones »
The other option would be to mount a gold paint pen to the carriage and DRAW the gold band around the red R. That would make it a two layer piece.
http://youtu.be/9BrV_eQ76W0
Franklin, KY., USA
Samson 510 & 4x4
CreatBot D600 PRO 3D Printer
16 Lasers
FREE DesignEdge Training!
Joe Jones
Post by Joe Jones »
Actually, this is the BEST way to make the piece, using THREE layers.
Franklin, KY., USA
Samson 510 & 4x4
16 Lasers
ROKCRLER
Post by ROKCRLER »
I searched and found this cleaner image then traced bitmap.
4x8 Dynatorch
PM85
~Mo~
ROKCRLER wrote: Sat Sep 10, 2022 6:51 pm I searched and found this cleaner image then traced bitmap.
Is this the image you used for the svg you provided above? OK - I did an auto trace and answered my own question. This one could be edited to more closely match the corners and sides to the original image you have provided, and then combine with a trace of the original decal image shown in the first post. I had searched for a similar image, but could not find one.
For something super clean and accurate, I would consider creating the zeros as objects where the corner radii could all be matched automatically, then align and distribute to get the horizontal spacing equal. And probably creating the R from scratch as well to assure symmetry. It all depends on how accurate the OP wants or needs. For plasma cutting at a smaller size for display, it may not matter much. But for 3D printing a replacement emblem, I would think it should be as accurate as possible to match the existing item.
ROKCRLER
Post by ROKCRLER »
yes sir
4x8 Dynatorch
PM85
~Mo~
ROKCRLER
Post by ROKCRLER »
Here is how I did the image:
1. Import the jpeg
2. Trace bitmap, multiple scans, colors, remove background
3. Ungroup (ctrl, shift, G)
4. Delete green items
5. Drag black item down and break apart (ctrl, shift, K)
6. Union (Ctrl + +)
7. Select gold numbers and letter
8. Break apart (ctrl, shift, K)
9. Select the numbers and combine (ctrl K)
10. Select the gold R, move to bottom (End Button)
11. Select part inside the R, hold shift and select gold R, with both selected, Difference ((ctrl - -)
12. Select gold numbers and gold R and Union (ctrl + +)
13. Select black object and gold objects and align center and horizontal
14. Select Blue R and change color to Red
15. Now you have 3 objects: Black background, gold numbers and R, and red R
As David posted above, you'll have to manipulate some of the corners on the zeros to match.
4x8 Dynatorch
PM85
~Mo~
Here is what the solid model would look like using the manual trace svg I posted previously. Fusion 360 seems to do better importing svg files as opposed to dxf files. I would need the actual dimensions of the part in order to edit the solid model and produce the final stl file for 3D printing.
And here it is ready to print.
I seem to recall a post where Tom showed creating masks cut from adhesive backed vinyl using a drag knife on his table. This method could come in handy for masking the letter "R" if it is to be painted after cnc plasma cut for a layered piece.
mcmental
Post by mcmental »
WOW thank you, just woke up herre in the UK to find all this help!! this is why i love this forum. im going to do some practice following your steps after a good dog walk this morning.
Here is an improved version of my original. I used Rokcrler's internet image to work with. I created the zeros as objects (rectangles with rounded corners) and matched the size to the image. Once the first rectangle is created, it can be duplicated to create 3 identical "zeros". I used the Align & Distribute tool for equal spacing between the zeros and to make them centered vertically. Same for the number 1. Then manually traced the R and outside border. Using the control key "Ctrl" when tracing using the Bezier drawing tool will keep the lines either vertical or horizontal.
1000R flat and symetrical.svg
ROKCRLER wrote: Sat Sep 10, 2022 9:35 pm Here is how I did the image:
1. Import the jpeg
6. Union (Ctrl + +)
:Like :Like :Like
Using a drag knife to cut vinyl is one way. another would be 3-D printing the parts to make a layered Badge. I would print a backer then the 1000, the "R" base and the the "R" top outline. Both os Davids STL images give a visual of how that would appear. Either a dual nozzle 3-D printer could be used. or there is a way to pause the print to change colors while printing for the layered look. I did that for a clock face project.
Another method is use the vinyl cutting for masking Aluminum to etch the design with Ferric Chloride (I used Muriatic acid and Hydrogen Peroxide mix)
https://www.youtube.com/watch?v=PkW0XotNmYo&t=6s
https://www.youtube.com/watch?v=gn1Xh9PaInc
Joe Jones
Post by Joe Jones »
Wow! Where did you find that? I searched for it but no joy.
Franklin, KY., USA
Samson 510 & 4x4
16 Lasers
ROKCRLER
Post by ROKCRLER »
4x8 Dynatorch
PM85
~Mo~
Joe Jones
Post by Joe Jones »
Thanks! don't you wish they would stop using the crappy RASTER images for stuff like this?
Franklin, KY., USA
Samson 510 & 4x4
16 Lasers
Joe Jones
Post by Joe Jones »
Here is the file in DXF format. I traced the logo using DesignEdge.
1000R DXF.dxf
Franklin, KY., USA
Samson 510 & 4x4
16 Lasers
mcmental
Post by mcmental »
Thank you everyone for your replies and help, I’m going to sit down tomorrow and digest everything and try to learn.
