Been looking for a gun and have looked at all the regulars - Eastwood dual, EZ100, EZ50, Harbor, etc. I am looking for a gun as an amateur coating parts in my garage for personal projects.
So Columbia makes this gun but there are no electronics and nothing to plug into the wall. There are a few reviews and a video that say it's great.
In the video, it looks like it works well but then how come every other company's guns are more involved and costly if this is such a great idea?
Has anyone else used it?
Here is the video. The guy said he has had problems but it sound like he solved them by cleaning the gun better.
Thoughts?
Kool Koat Quik Shot Powder Gun
Re: Kool Koat Quik Shot Powder Gun
I have the Eastwood single voltage model and it has worked well for years. Without electricity to charge the powder i am not sure how you would ever get powder into corners and tight spots. I have used a professional gun and yes it works better than my Eastwood but it was around $3000 so unless your using it everyday its not worth it. I am happy with the Easywood and would recommend it. For the money you cant go wrong.
This would be the same as turning the KV down to zero with a regular gun. Not very efficient but would be ok for small stuff.
Remember he is comparing it to a cheap Eastwood which would be a beginner gun.
I would think this would work fine for little stuff like he is coating.
That gun uses "Static electricity" as a charge on some powders and right weather it works!hotrod56 wrote: ↑Thu Dec 29, 2022 12:41 pm Been looking for a gun and have looked at all the regulars - Eastwood dual, EZ100, EZ50, Harbor, etc. I am looking for a gun as an amateur coating parts in my garage for personal projects.
Thoughts?
A friend tried it just before I was going to buy one and said "Don't waste your money!" dose not work with "Metallic powders"
I use the Eastwood Dual Voltage gun ($99 4.5 years ago) it's well worth the money (Use a good earth ground and clean hooks to hang parts) I hang parts from a 1/2" copper rod connected to a 8' earth ground outside the shop!
My "Big" gun is the EZ50 I was going to get a Kool-coat but it would only be better for 2% of what I do! 700 pieces in the past 3 years from .5" x 1" part to 36" x 44" Bucky Badger! There again "well worth the price" for the 50!
Both pics below is using the Eastwood gun! All colors done then cleared and baked!
You need to have VERY LITTLE powder in the bottle, turn the air down until you get a little puff when you squeeze the trigger, exhaust fan off most times while coating, aim and do quick shots of powder until you get the desired effect! After I do all the colors I use the 50 with clear or Starlite clear to coat them in case I'm thin in some areas!
Have fun and experiment!
My 2 cents worth!
