ClaudioK Plasma Mach3
Hi, nice too meet you for all you .I Have Make Table Plasma with 4 Motor Nema34 Closed Loop , with Ballscrew and Guide Hgh25, Controller Csmio-Ip/m .. Sorry for my english.
Re: ClaudioK Plasma Mach3
Welcome to the site ClaudioK. Would be interested in seeing your plasma table if you could post some pictures.
Are you using the onboard THC on the csmio ipm? Have you looked at cslabs simcnc controller software? I used cslabs csmio ipm on my first table, the onboard thc worked well.
Hi , sorry for my response slow , yes i used THC onboard Csmio of years , it s good , need good setting with Potenziometer , i think very good for Mach3 with Brain - IN OUT- csmio for regolation very perfect , i with Mach3 and Steel 0,8 mm When cut with Hypertherm Powermax Sync 65 1,65 V for good setting. Now I used SIMCNC , for now it s Good but i have only 3 Test , i sure think buy it , with mach3 Firmware 2910 i have Problem With refresh Dro , with License Mach3 not Cracked. In next day i send Image for your request. Very thanks and sorry for my little English
