DIY toolboard
DIY toolboard
Decided to build a toolboard for the new shop instead of buying something, will post pics when it's all up and done, here are some pics of the cutting process.
Re: toolboard
Neat you got a lot of tool, that many I'm sure you came out cheaper cutting verse buying. I'm assuming the star like things are knob handles, I cut some for a grinder I made. Some were 3-D printed too (red ones)
Re: toolboard
That's exactly what they are for, I built some roller stands and they are used to lock the up/down position.acourtjester wrote: Sun Dec 18, 2022 4:36 pm Neat you got a lot of tool, that many I'm sure you came out cheaper cutting verse buying. I'm assuming the star like things are knob handles, I cut some for a grinder I made. Some were 3-D printed too (red ones)
Re: toolboard
Yours are a lot fancier than mine are, I like the plastic ones espeacially.acourtjester wrote: Sun Dec 18, 2022 4:36 pm Neat you got a lot of tool, that many I'm sure you came out cheaper cutting verse buying. I'm assuming the star like things are knob handles, I cut some for a grinder I made. Some were 3-D printed too (red ones)
Re: toolboard
If you have a 3-D printer i can send the files, I used a 3/8" bolt so it fit nice.
Re: toolboard
That's one Heavy Duty pegboard! I will look forward to seeing the finished result with tools mounted for easy reach.
Re: toolboard
Wow, that's an undertaking and awesome idea. Hopefully you have a tumbler or acid bath to de-slag all those parts! Look forward to seeing it done.
Re: toolboard
No I don't have a printer but thanks for offering.acourtjester wrote: Sun Dec 18, 2022 8:31 pm If you have a 3-D printer i can send the files, I used a 3/8" bolt so it fit nice.
Re: toolboard
I just put 40 or so in a pail at a time and shake it around for a little bit, takes about 85% of slag off, the last pic shows the parts deslagged. I know, I need to build me a tumbler...one more thing on my to do list.cuttinparts wrote: Mon Dec 19, 2022 10:01 am Wow, that's an undertaking and awesome idea. Hopefully you have a tumbler or acid bath to de-slag all those parts! Look forward to seeing it done.
Re: toolboard
Went back to the pics and ya it looks like your pail shaking technique works really well for those small parts. That's great. Another clever ideaJason@bc wrote: Mon Dec 19, 2022 10:14 amI just put 40 or so in a pail at a time and shake it around for a little bit, takes about 85% of slag off, the last pic shows the parts deslagged. I know, I need to build me a tumbler...one more thing on my to do list.cuttinparts wrote: Mon Dec 19, 2022 10:01 am Wow, that's an undertaking and awesome idea. Hopefully you have a tumbler or acid bath to de-slag all those parts! Look forward to seeing it done.
Re: DIY toolboard
Jason check out YouTube many DIY tumblers shown there and some guys use a Harbor Freight cement mixer for dross removal.
Re: DIY toolboard
I like the cement mixer idea, might be the least expensive way to go, thanks Jester.
- ROKCRLER
Re: DIY toolboard
One thing i started doing to deslag multiple parts is placing in the skeleton or tabbing them then wire cup while they're in the skeleton
4x8 Dynatorch
PM85
~Mo~
PM85
~Mo~
Re: DIY toolboard
Here are more pics of my tool board...amongst other stuff for the new shop, now to get this all painted...
Re: DIY toolboard
I’m an ammunition reloader and I clean my brass cases to a high polish using a 1.5 cubic yard Harbor Freight cement mixer. It works well and I run about 5,000 cases at a time with a 70/30 dry mix of crushed walnut shells and corn Cobb bird / reptile mix I buy in bulk cheap from a local pet supplier. Many guys tumble wet with water detergent and stainless steel pellets. I have no doubt this method would work great to remove most all of the slag and clean and polish up the surfaces nicely. I going to try this when I make small parts.acourtjester wrote: Mon Dec 19, 2022 10:45 am Jason check out YouTube many DIY tumblers shown there and some guys use a Harbor Freight cement mixer for dross removal.
Re: DIY toolboard
I decided to do the same but made some minor adjustments.
The old style plastic tubs I cut out of 3 and 2mm sheet. Folded them up to the required shape. They can be tacked in some spots for strength.
The 3mm was my first attempt but it is a little heavy than necessary. My second attempt was made out of 2mm which is much better plus I made some minor adjustments again.
Also made a separate bracket for hanging other bits from. Also shows how it connects to the board...both front and back views.
The slots are 40mm long by 7mm wide spaced 25mm apart from centres.
Mtw fdu.
Mtw fdu.
Camcutcnc 4 x 4 plasma cutter with UC 100 Motion Controller
Powermax 45 with Machine Torch
Bobcad V27 and Mach 3
Proma THC
Now with Rotary Axis
Laser cross hairs
Proma THC
Laser cross hairs
Re: DIY toolboard
Those look nice and heavy duty! Great work with your fitment and thanks for sharing the photos with us.Mtw fdu wrote: Tue Mar 14, 2023 1:29 am I decided to do the same but made some minor adjustments.
Mtw fdu.
Re: DIY toolboard
Thanks David for your comments. Trying to show how they lock in the slot without falling out.
Mtw fdu.
Mtw fdu.
Proma THC
Laser cross hairs
Proma THC
Laser cross hairs
Re: DIY toolboard
Awesome! Looks like a lot of work but well worth it. Well done
Re: DIY toolboard
They appear to lock into the slot very well, and should be able to support quite a load. I will look forward to seeing some photos of your finished assembly.Mtw fdu wrote: Tue Mar 14, 2023 1:36 am Thanks David for your comments. Trying to show how they lock in the slot without falling out.
Mtw fdu.
Re: DIY toolboard
Made up the mounting plate for the utility bins. Mounted it to a post in the workshop near some welding consumables.
Slots are 100mm apart.
Turned out pretty good. Still deciding what colour to paint the bins...might do a clear coat. I don't mind the look of plain steel.
Mtw fdu.
Mtw fdu.
Proma THC
Laser cross hairs
Proma THC
Laser cross hairs
Re: DIY toolboard
Those look great! I personally like the look of the bare steel, and often spray it with clear satin Krylon. Keep up the good work.
Re: DIY toolboard
Thanks David. Went with the natural steel look and sprayed them with a clear coat. Need to get more material to finish off the other 2 spots above.
I didn't worry about tacking the corners together...for what they will be used for they are strong enough as they are.
I only cut the slots which were necessary, it will stay just like that.
I have a few other designs once I get a chance to do another workshop extension where more storage will be needed. However, I may do smaller sections when the need arises for my existing space.
Mtw fdu.
Mtw fdu.
Proma THC
Laser cross hairs
Proma THC
Laser cross hairs
Re: DIY toolboard
Nice work Mtw fdu, a (well thought out and organized storage/work-station) can save a ton of time, my only problem sometimes is keeping it that way...LOL.
