Hello, I have been asked to cut some parts that are circular with a hole in the middle, and a pattern of 5 equally spaced holes .200 from the edge.
I have no trouble drawing the main shape, and the internal hole. I see the program has a tool for bolt circles, But I cant get it to do squat.
Any help pointers or direction would be much appreciated! thanks guys!
Solid Edge 2d bolt hole patern
- tnbndr
Re: Solid Edge 2d bolt hole patern
I don't use solid edge but it took almost a minute to draw in Autocad. Since you did not specify size of holes or circle or anything for that matter you will have to edit this file.
I used polar array to get the five equally spaced lines.
- Attachments
- circle.dxf
- (127.99 KiB) Downloaded 57 times
- circle.dxf
Hypertherm PM30 Hand Torch
13.8scfm@100psi, 3450RPM
