I have a roughly 4' x 4' aluminum (1/4") ranch sign I'm finishing up for a customer. The customer really like the swirl pattern she has seen in some of my wall hangings (120 grit flap wheel on mild steel, under Steel F/X patina and clear). This aluminum panel will be bare, just swirled and clear coated.
I'm curious how to get a good "swirl" pattern on this. I tried the 120 grit flap disc on a piece of scrap, and it just looks awful. Dull, flat, looks more like scratches than a swirl finish. Actually looks WORSE than the original finish, IMO. Do I need to use something like a scotchbrite pad to get the effect I want? Something like this, on a grinder backer plate?
http://www.lehighvalleyabrasives.com/co ... 02-scd4-vf
Or a "conditioning flap wheel": http://www.lehighvalleyabrasives.com/no ... -fd45nw-vf
I'm new to aluminum finish work, so I'm not sure of the best way to go. The clear coat should add some shine, but I'd like to know the best prep option for the metal.
Putting a random swirl finish on aluminum
Re: Putting an swirl finish on aluminum
Not sure if this will help but the process for what is called "engine tune finish" uses a compound and a leather pad. Aluminum is to soft for a flat wheel
Thanks. I'm not really looking for an engine turned circular pattern finish, as much as a random "swirl pattern". She really liked the pattern under my patina'd monograms, so that is what I'm trying to duplicate. Similar to this swirl pattern on this piece:
Or like the pattern under this ribbon image I found:
Re: Putting a random swirl finish on aluminum
yes that is quite a different swirl pattern from engine turned, almost looks like a fish scale pattern in some places. But more like a random swirl, no pattern, good luck on that one.
Try an 80 grit flap disk..
1250 hypertherm
4 X 8 Precision Plasma
CandCnC electronics
CandCnC electronics
I tried a 120, and IMO it looks horrible.Largemouthlou wrote:Try an 80 grit flap disk..
Sending you a message
1250 hypertherm
CandCnC electronics
CandCnC electronics
Scotch pad discs is what I use.
https://www.mcmaster.com/#sanding-discs/=16ginfb
Platform CNC Plasma table
CandCNC Ethercut IV DTHC
Hypertherm 85/CPC/RS485
Miller 350P
Miller Dynasty 280DX
Miller 350P
+1 on the flap disc with scotch pad. I use the "medium" grit, shown here: http://www.cgwcamel.com/catalogue/product/3558
I know it says it is for stainless, but works great for aluminum. Also has a "very fine" grit, closer to about 320 grit nominal.
5x10 ArcLight Dynamics Plasma table
http://www.thesteelyardinc.net
We do it with a 36 Grit Disk on a 4.5" Grinder....
