Chinese plasma tips
Information on plasma cutting nozzles, electrodes, and other consumables.
busterm8
Chinese plasma tips
Post by busterm8 »
Anyone out there had experience buying tips or consumables from china?they are cheap but are they a ny good?
Re: Chinese plasma tips
I know our tech service group troubleshoots a lot of issues that get traced back to aftermarket consumables.....from short life, to bad cut edge angularity, to damaged torch bodies. Hypertherm currently has a patent infringement case against at least one Chinese consumables supplier.
Generally...buying consumables that are not genuine for a modern plasma torch is a crapshoot at best. In most cases you save a lttle at the time of purchase....but over time you lose a lot through additional grinding, changing the parts more often, as well as potential system downtime.
Jim Colt Hypertherm
SomethingMetal
Post by SomethingMetal »
Not worth the head aches that come with the cheap prices. Seeing what great cut quality I get from the Hypertherm consumables I have no reason to try and save a couple of dollars....
Samson 510
Hypertherm PM85
cstroke
Post by cstroke »
I have never gotten anything of quality from China..
not worth the hassle IMO..
Hypertherm parts is my choice..
6’x12’ Dynatorch powermax 85
12’ Wysong brake
5’x 5/16’ wysong rolls
3.8’x10’ shear
65 Ton ironworker
Boss laser 3655 150 watt CO2.
SFX 100watt Mopa
Quicncy 7.5hp
metalworxfabricators
Post by metalworxfabricators »
I recently unknowingly bought some knock off consumables on ebay. After using a few I noticed short consumable life and lots of fault errors. After some research I found out they came from China. They were about 1/2 price but not worth a crap.
Metalworx
DXF
Post by DXF »
metalworxfabricators wrote:I recently unknowingly bought some knock off consumables on ebay. After using a few I noticed short consumable life and lots of fault errors. After some research I found out they came from China. They were about 1/2 price but not worth a crap.
Metalworx
I had the same experience.....never again!
Dave Hanks
Wise john
Post by Wise john »
If you are using the chinese can you use the hypertherm model or any other good model that has nothing to do with chinese..... because the ones i have is really frustrating me
Wise john wrote: Sat Mar 06, 2021 6:19 pm If you are using the chinese can you use the hypertherm model or any other good model that has nothing to do with chinese..... because the ones i have is really frustrating me
You will want to use genuine Hypertherm consumables for your Hypertherm machine.
Scratch
Post by Scratch »
I bought a pack of Amazon consumables for my TD just to try them out. Electrodes and a few different sized tips. I was very happy with them. Can't tell any difference! I'm still working my way through them.
abmetal
Post by abmetal »
Maybe I'm looking at it wrong but I don't understand why anyone would want to mess with Chinese consumables and the aggravation and downtime that comes with them when, with proper use, American made consumables will provide much better results, less downtime.
Allen
abmetal wrote: Thu Mar 11, 2021 9:02 am Maybe I'm looking at it wrong but I don't understand why anyone would want to mess with Chinese consumables and the aggravation and downtime that comes with them when, with proper use, American made consumables will provide much better results, less downtime.
Allen
They are trying to save a few bucks.
Scratch
Post by Scratch »
Allen
I bought mine because they were cheap and I wanted to try them. I have no regrets, might even buy them again since they seem to last as long as the original ones.
It probably depends on what brand of machine you have. For the Hypertherm, Thermaldynamics, Miller, Lincoln, and other US made machines it is a good idea to stick with the OEM parts. For other Offbrand/China import machines, these chinese consumables are probably fine and most likely the same as the OEM parts those import machines came with.
Scratch
Post by Scratch »
The ones I have work fine on my TD Cutmaster 82.
Maybe I just got lucky...
Return to “Plasma Consumables”
