Mach3 how do you set thc to a negative value?
PlayingDirtyRacing
Post by PlayingDirtyRacing »
I just spent the past couple hours searching for an answer. How do you set the thc minimum to a negative value? I have the proma thc, and it absolutely will not go below 0.000 inch. It functions perfectly besides this. I have tried numerous different times to set the minimum thc to a negative number. Mach3 just will not allow me to put the negative symbol on the line. I watched some videos and tried to enter the value exactly as shown. But still no luck. Am I missing something here?
Can someone please give me a step by step process on how to do this. It is really bothering me.
Any help will be greatly appreciated, I am not real good with computers, but can normally figure stuff out with the Internet and you tube. But this one has me stumped.
Thank you.
Re: Mach3 how do you set thc to a negative value?
Post by tcaudle »
There is no proc4ess if the screen set they provided or that you are using won't take a negative number into the OEM DRO . You set in the screen painter what size and type numbers it will take. The THC Min and MAX values are added to the screen set and the values stored in the XML file.
The vendor that supplies you the custom screens and/or Profile (XML) for their products should be able to help you. If not you may want to rethink your choice of vendors.
East German
Post by East German »
Hello,
Here is a modified set file of mach 3.
Unpack and into the folder of Mach 3.
Press the View Button and load the set file.
Change the setting and return to yours set file!
Regards Peter
Plasma DirtyRacing.zip
(13.76 KiB) Downloaded 128 times
MyPlasmCNC
Hypertherm Powermax 85
Machine Torch
Hypertherm Powermax 1100
Machine Torch
rbmgf7
Post by rbmgf7 »
Return to “Mach3 & Mach4 CNC”
