Trouble shoot THC
Trouble shoot THC
What is the procedure (if any) to trouble shoot the THC, to confirm if it is bad or not. I'm sure some has touch on this before but I can seem to find where. I've used the search and haven't found any procedural way to determine if the THC needs to be replaced. Thank you in advance.
- WyoGreen
Re: Trouble shoot THC
What THC are you using?
Router
Laser
Router
Laser
This is not a primary hardware support forum. Its just users like yourself that mostly have file or cut issues.
Since you appear to have a Arclight table (I found it from som eof your other posts) I would contact them on how to troubleshoot the THC.
Failing that, you can contact the Support Forum of the THC manufacturer
In any case basic information is needed. Approximate age of the system. Model of the THC, what its doing, can you cut with the THC off
Baseline voltages while cutting.
I did find the problem, It was the Voltage divider board. Replaced and operation back to normal.
