Layers in bobcad v27
BobCAD related questions, tips and topics can be posted here
ggeh
Post by ggeh »
I'm using bobcad V27 and Somehow I ended up with multiple layers in a drawing that I'm working on. My question is, is there a way to combine all the layers on to one layer because I'm having trouble editing the drawing that has parts of it on different layers?
Thanks Gary
Mtw fdu
Re: Layers in bobcad v27
Post by Mtw fdu »
I too have version 27 and I may have a solution.
If you copy the completed drawing on another page and save as something different. This may or may not work as I also have issues with the layer system they have. Just a thought.
Mtw fdu.
Camcutcnc 4 x 4 plasma cutter with UC 100 Motion Controller
Powermax 45 with Machine Torch
Bobcad V27 and Mach 3
Proma THC
Now with Rotary Axis
Laser cross hairs
ggeh
Post by ggeh »
Mtw fdu wrote:I too have version 27 and I may have a solution.
Mtw fdu.
Thanks I will try that and see if that works. I found an other issue when I use the three points to make an arc I'm not able to connect that arc with the other parts of my drawing. if the arc crosses another line and I try to trim the portion past the line that I dont want it removes the hole arc not just the portion the passes the line.
Return to “BobCAD”
