1250 g3 other charts
Lightning_strike
Post by Lightning_strike »
So I have a samson 510 with a powermax 1250, I have all the cut charts but I'm having a hell of a time finding charts for proper kerf (or nozzle orifice size to multiply it by 1.5), air pressures. I understand that hypertherm has multiple models but Why do we not have charts for these?
Samson 510
Hypertherm powermax 1250
campbell hausfeld 60 gal
Hobart ironman 230 :Yay
3/4" blade band saw
4ft finger brake
Miller diversion 180
Millermatic 140
Re: 1250 g3 other charts
I couldn't find kerf width charts for the 1250 either. Just set your machine up to cut a 6" straight line at the appropriate speed, height, and amperage and then measure the kerf width, document it for future reference and your all set :Like
SegoMan DeSigns
Post by SegoMan DeSigns »
Does it have the older machine torch or the newer Duramax? You could probably takes the values from the 85 and be close.
Lightning_strike
I have the T80 torche
Samson 510
3/4" blade band saw
4ft finger brake
Millermatic 140
Nacs Fab
Post by Nacs Fab »
I have some cut charts for this machine, let me see if I can find them and upload them here. At one point, I got the kerfs from either here or on another forum where Jim Colt posted for both the older torches as well as the new Duramax torch, which I have. Give me a day or so and Ill see what I can find.
G540 with LCTHC by candcnc
all built... by me...
robertspark
Post by robertspark »
not the answer you want but it was from Jim colt for the 1250 and he should know
https://www.cnczone.com/forums/hyperthe ... forum.html
robertspark
Nacs Fab
Post by Nacs Fab »
Here is what i use without any problems using my Duramax Torch but I also used it when I had my old T80M (i belive thats the name of it).
kerf width.doc
(302 KiB) Downloaded 53 times
kerf width.doc
Lightning_strike
Cool cool. I'll use the pm 85 chart as much as possible
Samson 510
3/4" blade band saw
4ft finger brake
Millermatic 140
