I have a hypertherm 45 cnc in Ireland and thinking about upgrading to xp. Has anyone here done this, and if so is it worth it. Thanks in advance!!
New here. Hypertherm 45, upgrade to xp ?
Hi all, thanks for adding me !!
Re: New here. Hypertherm 45, upgrade to xp ?
Welcome! I personally do not have a 45 or 45XP but know guys with the XP and apparently its night and day better than the 45.
Hi, someone told me that and i wondered if it was right, sounds like it is then. He said it cuts far faster. Thanks for that
ill have to start saving
- Ironken
An easy way to see if the cut speeds are higher with the xp vs the 45 is to compare cut charts. I believe that you can convert to a duramax torch and take advantage of the xp consumables. Might save you some money.Meself wrote: Tue Oct 22, 2019 3:28 pm Hi, someone told me that and i wondered if it was right, sounds like it is then. He said it cuts far faster. Thanks for thatill have to start saving
JD2 MAD 4X4
Millermatic 252 (spray)
Millermatic 190 (short circuit)
Syncrowave 210
Powermax 65
Powermax 45xp
Grizzly Vertical Mill (junk)
Baileigh BS-210M
50t Press
Shitloads of DeWalt
Syncrowave 210
Powermax 65
Powermax 45xp
Baileigh BS-210M
50t Press
Shitloads of DeWalt
