How to fill in drawing to show end results
james.davis
Post by james.davis »
How do you fill in a line drawing to show what the end result will look like with a PLASMACAM DHC2?
Jim
LIKE THIS
DR. LOUIE 2.dxf
DR. LOUIE 2.pcm
Re: how to fill in drawing to show end results
james.davis wrote: Sat Feb 29, 2020 11:17 am DR. LOUIE 2.dxfDR. LOUIE 2.pcm
Jim
LIKE THIS
download/file.php?mode=view&id=62739
Thee are many ways to do it, I sometimes run the verify program in my CAD/CAM but if you want a quick and dirty way just to see what it will look like just bring the file up on your screen with the whole part showing then hit the "Prt Scr" key. Next open "Paint" and click on the little clipboard that says "paist" under it. Then you can fill the solid parts of your file and leave the parts that you want a different color. If the whole page changes to to your paste color it means there is a leak somewhere, just click on the undo arrow in the top left corner and look for a line with a space in it and use the pencil to fill it in one pixel at a time. Here is your file, it took about one minute to do this one.
harrymorley
Post by harrymorley »
touch f5..then control w
james.davis
Thanks very much. That will make it so much easier to to check every thing out
Jim
Joe Jones
Re: How to fill in drawing to show end results
Post by Joe Jones »
Those files have MANY issues. They are not ready to be cut on a PlasmaCam table.
