I'm fixing to do my first outdoor aluminum signs and would appreciate some advice.
They will be single layer cut from .125" Aluminum. The customer would like them to be painted matte black. Any considerations regarding surface prep? Is there a special primer I should use to promote adhesion of the top coat? Thanks!
Need advice on finish for outdoor aluminum signs
Re: Need advice on finish for outdoor aluminum signs
I clean with a auto body type wax and grease remover and a rag, sandblast the material, blow clean with compressed air (don't wipe with rag or fuzz will stick to your part) and paint. Never had a problem and the finish is tough and very resistant to chipping.
Sounds like a plan. Thanks plasmanewbie.
