Nice square edge
Thats one I cant do on my plasma cutter.. The machine is not big enough, but I can cut it on the laser..ronsii wrote:Nice work rock4xfab, Looks Great!!!
now if I could get 5/8's to look that good I would be all set, I am close but not perfect.
evoandyvii wrote:That is a really nice cut quality rock4xfab.
I'm new to the forum and i also have a TD 152 set up on a water table. I use SheetCAM and MACH3 to generate and run the g-codes. For a while i thought i was going crazy because the Specs in the owners manual weren't producing a very good cut quality. Once i saw your specs i knew that the book was worth tossing out.
I'm trying to cut half inch and 3/4 inch steel and i'm having a hell of a time getting it to even cut all the way through the metal let alone cut nicely. If you have any other cut quality tips on thicker metals do you mind if I could pick your brain for the info?
