Newb to cnc plasma
NickAlpha
Newb to cnc plasma
Post by NickAlpha »
Hi Guys, I found your forum while weighing up the pros and cons of a plasma table. We currently metal stamp a lot of our parts but am thinking the time to move to a cnc table might be now. I am in South Australia.
Cheers Nick
Re: Newb to cnc plasma
Welcome aboard there are others here from Australia, May help in your selection
NickAlpha
Post by NickAlpha »
Cool, I'll keep an eye out.
NickAlpha
Post by NickAlpha »
I have a question for someone with more experience than me (so basically everyone here). I have a hypertherm 125 with handheld torch at the moment. If I had that machine (with appropriate torch) mounted in a cnc table and were cutting 7/8 diameter holes in 5/8 thick mild steel plate, how much taper should I expect?
robertspark
Post by robertspark »
minimum hole diameter with air plasma tends to be 2:1 (i.e twice the thickness). I only do thin stuff so 3:1 is my limit of what I have managed otherwise I spot and drill below 3x thickness.
5/8 X 2 = 1 1/4" dia min....
5/8 X 3 = 1 7/8" dia....
high definition plasma and truehole is 1:1 but a whole other price league than air plasma.... (being a hobby user I've never seen one in the flesh working so it's all a guess and from what I read)
NickAlpha wrote: Mon Jul 27, 2020 7:47 am I have a question for someone with more experience than me (so basically everyone here). I have a hypertherm 125 with handheld torch at the moment. If I had that machine (with appropriate torch) mounted in a cnc table and were cutting 7/8 diameter holes in 5/8 thick mild steel plate, how much taper should I expect?
Here is some information from Jim Colt of Hypertherm on the subject.
hyperthermholes.pdf
(708.31 KiB) Downloaded 55 times
hyperthermholes.pdf
Rodw
Post by Rodw »
NickAlpha wrote: Sun Jul 26, 2020 6:42 am Hi Guys, I found your forum while weighing up the pros and cons of a plasma table. We currently metal stamp a lot of our parts but am thinking the time to move to a cnc table might be now. I am in South Australia.
Cheers Nick
Nick welcome aboard. I am in Brisbane. There is a very active group of Aussies using Linuxcnc's plasmac config. See http://linuxcnc.org/docs/2.8/html/plasm ... guide.html
In fact, the Plasmac developer is based in Melbourne.
NickAlpha
Post by NickAlpha »
Thanks for the info Guys. What sort of machine are you running Rod? Will the linuxcnc take a dxf or do you need to Gcode your parts?
Rodw
Post by Rodw »
Nick, I built my own table. (The Spaceship). There are some details here
viewtopic.php?f=103&t=22826
The spaceship has recently has morphed into a commercial prototype so one day we may be able to offer a carefully engineered package complete with prebuilt a controller.
I think there is a program called gcodetools (a part of inkscape I think) which will send DXF to Linuxcnc.
But I always use Sheetcam to lay out dxf's and convert to gcode as I generally cut a few parts or a sheet at a time.
