anybody want to help with this file when I traced in inkscape the font was so distorted I cant save it and was unable to find the fonts online to start from scratch
I know its a simple one but im pretty new at this and my orders are coming in not letting much time for software catchup
customer wants it 8-10 feet wide with two colors ,but with out the phone number or the town and state
seamless spouting sign
- Larry83301
Re: seamless spouting sign
Contact one of the people on the board to make it for you, like ben de lappe or one of the others that do files to order.
Machinist,
seeing as work is coming in and this is business, and you can't do this yourself, as Larry said it would be best to directly contact one of the guys here that do paid work for converting. It sounds like you are going to need regular conversions done until you get time to go through some Inkscape tracing tutorials (plenty of them on Youtube apparently).
The conversion guys are all listed in this thread:
https://www.plasmaspider.com/viewtopic.php?f=98&t=27175
2500 x 1500 water table
LinuxCNC
Coreldraw 2019
LinuxCNC
Coreldraw 2019
See if this will get you started. It needs some additional cleanup, but I did the auto-trace with Inkscape and it may be something you can work with.
thats alot better than i got with inkscape , thank you for the help
I am learning slowly but got a ways to go
Sometimes is help to manipulate the image before you trace, I think David said he changes the brightness and contrast first. There is a video using the Paint program to isolate things before bringing them into Inkscape. Thanks to RDJ357
This helped a lot to break apart a drawing and saving them as separate files and them bringing them into Inkscape by using the import function to join them again. You can select different areas in the image and manipulate it to get the parts you want then save them.
That's a great video that Robert made. He uses Paint, VinylMaster, and Design Edge to complete the processing of the sample image. I don't believe he used Inkscape in this video (maybe I missed it).acourtjester wrote: Sat Nov 14, 2020 12:07 pm Sometimes is help to manipulate the image before you trace, I think David said he changes the brightness and contrast first. There is a video using the Paint program to isolate things before bringing them into Inkscape. Thanks to RDJ357![]()
You are correct, he generated the video to answer the question I had about how he used Paint to aid the process. I have used the Paint program as described above when I do traces, in selecting (manipulating the data) items in the original image. As with many of us he uses other programs to finish the project, I like Inkscape.
