Mach 4 shutting down on downloaded files
Ok so i recently upgraded my thc too a TMC 3 in 1and it required me too run mach 4 instead of mach 3. So i get everything set up and running and any file that I have drawn on my computer will cut just fine but any file that i download or someone emails me will cut about half the file and completely shut down mach 4 and bury the z axis until I hit the E stop. Any Ideas? literally every file
Re: Mach 4 shutting down on downloaded files
Please post one of the files you are having problems with so we can take a look.
So the files that are cutting fine are you just running the g-code you have cut with in the past?
The new files you download or have sent to you that don't cut properly you will be generating g-code to cut those so maybe it is a post processor issue with your new setup.
question does this happen while cutting the first cut of an operation, like the torch fires and cut half of the part and the torch dives at that point.
If so I would look for a loose wire in the arc voltage area.
Everything i have cut has been ran back through sheetcam with my new post processor set up too have a new gcode for the new torch height control too work.weldguy wrote: ↑Thu Dec 10, 2020 10:05 am So the files that are cutting fine are you just running the g-code you have cut with in the past?
I just got into a cut too about my 15th cut of the g code and then mach 4 shut down and closed and once it closes my torch stays on and the z axis plungesacourtjester wrote: ↑Thu Dec 10, 2020 10:24 am question does this happen while cutting the first cut of an operation, like the torch fires and cut half of the part and the torch dives at that point.
heres a file that cuts about half way and crashes mach 4... I made it half way through the 11th cut when it screwed up
N0010 (Filename: creative air.tap)
N0020 (Post processor: TMC3in1 Mach4 v003.scpost)
N0030 (Date: 10/12/2020)
N0040 G20 (Units: Inches)
N0050 G53 G90 G91.1 G40
N0060 G64 (Constant Velocity Mode - normally used with Plasma)
N0070 m2020 (TMC3IN1_TARGET_TIP_VOLTS=105)
N0080 m2020 (TMC3IN1_TARGET_BAND_VOLTS=1.5)
N0090 m2020 (TMC3IN1_LINEAR_RESPONSE_BAND_VOLTS_ABOVE=25.25)
N0100 m2020 (TMC3IN1_LINEAR_RESPONSE_BAND_VOLTS_BELOW=15.2)
N0110 m2020 (ESS_DELAY_AFTER_ARC_OKAY=0)
N0120 m2020 (HC_Z_MAX_VALUE=1)
N0130 m2020 (HC_Z_MIN_VALUE=-0.1)
N0140 m2020 (TMC3IN1_AD1_DELAY_ENABLED=1)
N0150 m2020 (TMC3IN1_AD1_DELAY_VALUE=0.8)
N0160 m2020 (TMC3IN1_AD2_M62_M63_ENABLED=0)
N0170 m2020 (TMC3IN1_AD3_VELOCITY_ENABLED=1)
N0180 m2020 (TMC3IN1_AD3_VELOCITY_PERCENT=95)
N0190 m2020 (TMC3IN1_AD4_VOLTAGE_ENABLED=0)
N0200 m2020 (TMC3IN1_AD4_VOLTAGE_BUFFER=800)
N0210 m2020 (TMC3IN1_AD4_VOLTAGE_CHANGE_PERCENT=4.01)
N0220 m2020 (TMC3IN1_AD4_VOLTAGE_RESPONSE_PERCENT=0)
N0230 m2020 (TMC3IN1_AD5_VOLTAGE_ABOVE=15.1)
N0240 m2020 (TMC3IN1_AD6_VOLTAGE_BELOW=14.4)
N0250 G4 P0.1
N0260 (Part: creative air)
N0270 (Operation: Outside Offset, 0, T7: 1/8")
N0280 G00 X13.7735 Y8.5592
N0290 (>>>Probe/Ref<<<)
N0300 G31.0 Z-10 F19.685
N0310 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N0320 G90 (Back to absolute move mode)
N0330 G92 Z0.0 (Z work coordinate set to 0.0)
N0340 m2020 (HC_WORK_Z_ZEROED=1)
N0350 G4 P0.1
N0360 G00 Z0.3394
N0370 G4 P0.001
N0380 M62P3 (>>>Torch ON<<<)
N0390 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N0400 G04 P0.05
N0410 G01 Z0.3300 F48.0
N0420 G02 X13.8246 Y8.5291 I-0.0709 J-0.1787
N0430 M63P4 (***THC Inhibited, AD2***)
N0440 X13.8688 Y8.4772 I-0.1220 J-0.1487
N0450 G01 X13.8691 Y8.4767
N0460 G02 X13.9063 Y8.3418 I-0.2167 J-0.1323
N0470 G01 Y8.3408
N0480 G02 X13.8463 Y8.1834 I-0.2214 J-0.0056
N0490 X13.6524 Y8.0993 I-0.2166 J0.2337
N0500 G03 X13.6423 Y8.0420 I0.0021 J-0.0299
N0510 G02 X13.7145 Y7.9971 I-0.1278 J-0.2859
N0520 X13.8189 Y7.8705 I-0.4512 J-0.4784
N0530 G01 X13.9634 Y7.6444
N0540 X13.8682
N0550 X13.7447 Y7.8385
N0560 G03 X13.6480 Y7.9782 I-1.6303 J-1.0264
N0570 X13.6237 Y8.0076 I-0.2668 J-0.1947
N0580 G01 Y8.1460
N0590 G03 X13.7044 Y8.1632 I-0.0543 J0.4534
N0600 G01 X13.7051 Y8.1634
N0610 G03 X13.7983 Y8.2354 I-0.0580 J0.1715
N0620 X13.8299 Y8.3412 I-0.1609 J0.1056
N0630 X13.7680 Y8.4809 I-0.1790 J0.0043
N0640 G01 X13.7661 Y8.4824
N0650 G03 X13.6237 Y8.5342 I-0.1601 J-0.2186
N0660 G01 Y8.5846
N0670 G02 X13.7735 Y8.5592 I-0.0182 J-0.5598
N0680 M62P4 (+++THC Allowed, AD2+++)
N0690 M63P3 (<<<Torch OFF>>>)
N0700 G00 Z1.0000
N0710 X13.2171 Y8.1165
N0720 (>>>Probe/Ref<<<)
N0730 G31.0 Z-10 F19.685
N0740 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N0750 G90 (Back to absolute move mode)
N0760 G92 Z0.0 (Z work coordinate set to 0.0)
N0770 m2020 (HC_WORK_Z_ZEROED=1)
N0780 G4 P0.1
N0790 G00 Z0.3394
N0800 G4 P0.001
N0810 M62P3 (>>>Torch ON<<<)
N0820 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N0830 G04 P0.05
N0840 G01 Z0.3300 F48.0
N0850 M63P4 (***THC Inhibited, AD2***)
N0860 X13.1669 Y8.1065 F33.6
N0870 Y8.5844
N0880 X13.4387
N0890 Y8.5339
N0900 X13.2692
N0910 G03 X13.2392 Y8.5039 I0.0000 J-0.0300
N0920 G01 Y8.5013
N0930 Y8.1731 F48.0
N0940 G03 X13.2692 Y8.1431 I0.0300 J0.0000
N0950 G01 X13.4387
N0960 Y8.0880
N0970 X13.4236 Y8.0884
N0980 X13.4227 Y8.0885
N0990 X13.2692
N1000 G03 X13.2392 Y8.0585 I0.0000 J-0.0300
N1010 G01 Y7.6444
N1020 X13.1669
N1030 Y8.1065
N1040 M62P4 (+++THC Allowed, AD2+++)
N1050 M63P3 (<<<Torch OFF>>>)
N1060 G00 Z1.0000
N1070 X12.8710 Y8.5844
N1080 (>>>Probe/Ref<<<)
N1090 G31.0 Z-10 F19.685
N1100 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N1110 G90 (Back to absolute move mode)
N1120 G92 Z0.0 (Z work coordinate set to 0.0)
N1130 m2020 (HC_WORK_Z_ZEROED=1)
N1140 G4 P0.1
N1150 G00 Z0.3394
N1160 G4 P0.001
N1170 M62P3 (>>>Torch ON<<<)
N1180 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N1190 G04 P0.05
N1200 G01 Z0.3300 F48.0
N1210 Y8.2444
N1220 M63P4 (***THC Inhibited, AD2***)
N1230 Y7.6444
N1240 X12.7987
N1250 Y8.5844
N1260 X12.8710
N1270 M62P4 (+++THC Allowed, AD2+++)
N1280 M63P3 (<<<Torch OFF>>>)
N1290 G00 Z1.0000
N1300 X12.3571 Y8.0356
N1310 (>>>Probe/Ref<<<)
N1320 G31.0 Z-10 F19.685
N1330 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N1340 G90 (Back to absolute move mode)
N1350 G92 Z0.0 (Z work coordinate set to 0.0)
N1360 m2020 (HC_WORK_Z_ZEROED=1)
N1370 G4 P0.1
N1380 G00 Z0.3394
N1390 G4 P0.001
N1400 M62P3 (>>>Torch ON<<<)
N1410 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N1420 G04 P0.05
N1430 G01 Z0.3300 F48.0
N1440 M63P4 (***THC Inhibited, AD2***)
N1450 X12.2527 Y8.3128
N1460 G02 X12.1825 Y8.5179 I2.5240 J0.9780
N1470 G03 X12.1243 Y8.5152 I-0.0288 J-0.0086
N1480 G02 X12.0718 Y8.3288 I-1.2207 J0.2437
N1490 G01 X11.9620 Y8.0356
N1500 G03 X11.9901 Y7.9950 I0.0281 J-0.0105
N1510 G01 X12.0638
N1520 Y7.9473
N1530 X11.9519
N1540 G03 X11.9236 Y7.9275 I0.0000 J-0.0300
N1550 G01 X11.8210 Y7.6444
N1560 X11.7452
N1570 X12.1062 Y8.5844
N1580 X12.2080
N1590 X12.5927 Y7.6444
N1600 X12.5072
N1610 X12.3980 Y7.9280
N1620 G03 X12.3700 Y7.9473 I-0.0280 J-0.0108
N1630 G01 X12.2487
N1640 Y7.9950
N1650 X12.3291
N1660 G03 X12.3571 Y8.0356 I0.0000 J0.0300
N1670 M62P4 (+++THC Allowed, AD2+++)
N1680 M63P3 (<<<Torch OFF>>>)
N1690 G00 Z1.0000
N1700 X11.2606 Y8.5844
N1710 (>>>Probe/Ref<<<)
N1720 G31.0 Z-10 F19.685
N1730 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N1740 G90 (Back to absolute move mode)
N1750 G92 Z0.0 (Z work coordinate set to 0.0)
N1760 m2020 (HC_WORK_Z_ZEROED=1)
N1770 G4 P0.1
N1780 G00 Z0.3394
N1790 G4 P0.001
N1800 M62P3 (>>>Torch ON<<<)
N1810 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N1820 G04 P0.05
N1830 G01 Z0.3300 F48.0
N1840 M63P4 (***THC Inhibited, AD2***)
N1850 Y8.5264
N1860 X10.6999
N1870 G03 X10.6699 Y8.4964 I0.0000 J-0.0300
N1880 G01 Y8.1901
N1890 G03 X10.6999 Y8.1601 I0.0300 J0.0000
N1900 G01 X11.2231
N1910 Y8.1028
N1920 X10.6999
N1930 G03 X10.6699 Y8.0728 I0.0000 J-0.0300
N1940 G01 Y7.7324
N1950 G03 X10.6999 Y7.7024 I0.0300 J0.0000
N1960 G01 X11.2838
N1970 Y7.6444
N1980 X10.5976
N1990 Y8.5844
N2000 X11.1976
N2010 M62P4 (+++THC Allowed, AD2+++)
N2020 X11.2606
N2030 M63P3 (<<<Torch OFF>>>)
N2040 G00 Z1.0000
N2050 X9.6505
N2060 (>>>Probe/Ref<<<)
N2070 G31.0 Z-10 F19.685
N2080 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N2090 G90 (Back to absolute move mode)
N2100 G92 Z0.0 (Z work coordinate set to 0.0)
N2110 m2020 (HC_WORK_Z_ZEROED=1)
N2120 G4 P0.1
N2130 G00 Z0.3394
N2140 G4 P0.001
N2150 M62P3 (>>>Torch ON<<<)
N2160 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N2170 G04 P0.05
N2180 G01 Z0.3300 F48.0
N2190 X9.7584 Y8.2828
N2200 M63P4 (***THC Inhibited, AD2***)
N2210 X9.9033 Y7.8777
N2220 G02 X9.9551 Y7.7161 I-2.1374 J-0.7749
N2230 G03 X10.0129 Y7.7160 I0.0289 J0.0081
N2240 G02 X10.0660 Y7.8774 I1.9766 J-0.5612
N2250 G01 X10.3289 Y8.5844
N2260 X10.3991
N2270 X10.0311 Y7.6444
N2280 X9.9364
N2290 X9.5722 Y8.5844
N2300 X9.6505
N2310 M62P4 (+++THC Allowed, AD2+++)
N2320 M63P3 (<<<Torch OFF>>>)
N2330 G00 Z1.0000
N2340 X9.3662
N2350 (>>>Probe/Ref<<<)
N2360 G31.0 Z-10 F19.685
N2370 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N2380 G90 (Back to absolute move mode)
N2390 G92 Z0.0 (Z work coordinate set to 0.0)
N2400 m2020 (HC_WORK_Z_ZEROED=1)
N2410 G4 P0.1
N2420 G00 Z0.3394
N2430 G4 P0.001
N2440 M62P3 (>>>Torch ON<<<)
N2450 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N2460 G04 P0.05
N2470 G01 Z0.3300 F48.0
N2480 Y8.2444
N2490 M63P4 (***THC Inhibited, AD2***)
N2500 Y7.6444
N2510 X9.2939
N2520 Y8.5844
N2530 X9.3662
N2540 M62P4 (+++THC Allowed, AD2+++)
N2550 M63P3 (<<<Torch OFF>>>)
N2560 G00 Z1.0000
N2570 X8.3455 Y8.5264
N2580 (>>>Probe/Ref<<<)
N2590 G31.0 Z-10 F19.685
N2600 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N2610 G90 (Back to absolute move mode)
N2620 G92 Z0.0 (Z work coordinate set to 0.0)
N2630 m2020 (HC_WORK_Z_ZEROED=1)
N2640 G4 P0.1
N2650 G00 Z0.3394
N2660 G4 P0.001
N2670 M62P3 (>>>Torch ON<<<)
N2680 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N2690 G04 P0.05
N2700 G01 Z0.3300 F48.0
N2710 M63P4 (***THC Inhibited, AD2***)
N2720 Y8.5844
N2730 X9.0782
N2740 Y8.5264
N2750 X8.7773
N2760 G03 X8.7473 Y8.4964 I0.0000 J-0.0300
N2770 G01 Y7.6444
N2780 X8.6750
N2790 Y8.4964
N2800 G03 X8.6450 Y8.5264 I-0.0300 J0.0000
N2810 G01 X8.3455
N2820 M62P4 (+++THC Allowed, AD2+++)
N2830 M63P3 (<<<Torch OFF>>>)
N2840 G00 Z1.0000
N2850 X8.1051 Y8.0356
N2860 (>>>Probe/Ref<<<)
N2870 G31.0 Z-10 F19.685
N2880 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N2890 G90 (Back to absolute move mode)
N2900 G92 Z0.0 (Z work coordinate set to 0.0)
N2910 m2020 (HC_WORK_Z_ZEROED=1)
N2920 G4 P0.1
N2930 G00 Z0.3394
N2940 G4 P0.001
N2950 M62P3 (>>>Torch ON<<<)
N2960 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N2970 G04 P0.05
N2980 G01 Z0.3300 F48.0
N2990 M63P4 (***THC Inhibited, AD2***)
N3000 X8.0006 Y8.3128
N3010 G02 X7.9305 Y8.5179 I2.5240 J0.9780
N3020 G03 X7.8723 Y8.5152 I-0.0288 J-0.0086
N3030 G02 X7.8197 Y8.3288 I-1.2207 J0.2437
N3040 G01 X7.7099 Y8.0356
N3050 G03 X7.7380 Y7.9950 I0.0281 J-0.0105
N3060 G01 X7.8199
N3070 Y7.9473
N3080 X7.6998
N3090 G03 X7.6716 Y7.9275 I0.0000 J-0.0300
N3100 G01 X7.5689 Y7.6444
N3110 X7.4931
N3120 X7.8541 Y8.5844
N3130 X7.9559
N3140 X8.3406 Y7.6444
N3150 X8.2552
N3160 X8.1459 Y7.9280
N3170 G03 X8.1179 Y7.9473 I-0.0280 J-0.0108
N3180 G01 X8.0049
N3190 Y7.9950
N3200 X8.0770
N3210 G03 X8.1051 Y8.0356 I0.0000 J0.0300
N3220 M62P4 (+++THC Allowed, AD2+++)
N3230 M63P3 (<<<Torch OFF>>>)
N3240 G00 Z1.0000
N3250 X7.3202 Y8.5844
N3260 (>>>Probe/Ref<<<)
N3270 G31.0 Z-10 F19.685
N3280 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N3290 G90 (Back to absolute move mode)
N3300 G92 Z0.0 (Z work coordinate set to 0.0)
N3310 m2020 (HC_WORK_Z_ZEROED=1)
N3320 G4 P0.1
N3330 G00 Z0.3394
N3340 G4 P0.001
N3350 M62P3 (>>>Torch ON<<<)
N3360 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N3370 G04 P0.05
N3380 G01 Z0.3300 F48.0
N3390 M63P4 (***THC Inhibited, AD2***)
N3400 Y8.5264
N3410 X6.7595
N3420 G03 X6.7295 Y8.4964 I0.0000 J-0.0300
N3430 G01 Y8.1901
N3440 G03 X6.7595 Y8.1601 I0.0300 J0.0000
N3450 G01 X7.2827
N3460 Y8.1028
N3470 X6.7595
N3480 G03 X6.7295 Y8.0728 I0.0000 J-0.0300
N3490 G01 Y7.7324
N3500 G03 X6.7595 Y7.7024 I0.0300 J0.0000
N3510 G01 X7.3434
N3520 Y7.6444
N3530 X6.6572
N3540 Y8.5844
N3550 X7.2572
N3560 M62P4 (+++THC Allowed, AD2+++)
N3570 X7.3202
N3580 M63P3 (<<<Torch OFF>>>)
N3590 G00 Z1.0000
N3600 X6.8685 Y9.2351
N3610 (>>>Probe/Ref<<<)
N3620 G31.0 Z-10 F19.685
N3630 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N3640 G90 (Back to absolute move mode)
N3650 G92 Z0.0 (Z work coordinate set to 0.0)
N3660 m2020 (HC_WORK_Z_ZEROED=1)
N3670 G4 P0.1
N3680 G00 Z0.3394
N3690 G4 P0.001
N3700 M62P3 (>>>Torch ON<<<)
N3710 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N3720 G04 P0.05
N3730 G01 Z0.3300 F48.0
N3740 M63P4 (***THC Inhibited, AD2***)
N3750 X6.9242 Y9.1521 F33.6
N3760 X5.9242 Y9.1495
N3770 M62P4 (+++THC Allowed, AD2+++)
N3780 X4.9473 Y9.1469 F48.0
N3790 M63P4 (***THC Inhibited, AD2***)
N3800 X4.3473 Y9.1453
N3810 G02 X4.3884 Y9.7436 I6.2764 J-0.1308
N3820 M62P4 (+++THC Allowed, AD2+++)
N3830 X15.2248 Y13.2854 I6.2353 J-0.7291
N3840 M63P4 (***THC Inhibited, AD2***)
N3850 X15.6114 Y12.8269 I-4.6011 J-4.2710
N3860 G03 X15.6522 Y12.8203 I0.0238 J0.0182
N3870 G01 X16.5540 Y13.4385
N3880 X16.4495 Y12.8477
N3890 M62P4 (+++THC Allowed, AD2+++)
N3900 X16.0593 Y10.6412
N3910 M63P4 (***THC Inhibited, AD2***)
N3920 X15.9548 Y10.0504
N3930 X15.3640 Y10.1547
N3940 M62P4 (+++THC Allowed, AD2+++)
N3950 X13.0921 Y10.5561
N3960 M63P4 (***THC Inhibited, AD2***)
N3970 X12.5013 Y10.6604
N3980 X12.9962 Y10.9997
N3990 M62P4 (+++THC Allowed, AD2+++)
N4000 X12.9987 Y11.0014
N4010 M63P4 (***THC Inhibited, AD2***)
N4020 X13.4936 Y11.3407
N4030 G03 X13.4998 Y11.3846 I-0.0170 J0.0247
N4040 X13.0815 Y11.8139 I-2.8621 J-2.3701
N4050 M62P4 (+++THC Allowed, AD2+++)
N4060 X6.9242 Y9.1521 I-2.4438 J-2.7994
N4070 M63P3 (<<<Torch OFF>>>)
N4080 G00 Z1.0000
N4090 X6.2548 Y8.5592
N4100 (>>>Probe/Ref<<<)
N4110 G31.0 Z-10 F19.685
N4120 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N4130 G90 (Back to absolute move mode)
N4140 G92 Z0.0 (Z work coordinate set to 0.0)
N4150 m2020 (HC_WORK_Z_ZEROED=1)
N4160 G4 P0.1
N4170 G00 Z0.3394
N4180 G4 P0.001
N4190 M62P3 (>>>Torch ON<<<)
N4200 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N4210 G04 P0.05
N4220 G01 Z0.3300 F48.0
N4230 G02 X6.3059 Y8.5291 I-0.0709 J-0.1787
N4240 M63P4 (***THC Inhibited, AD2***)
N4250 X6.3501 Y8.4772 I-0.1220 J-0.1487
N4260 G01 X6.3504 Y8.4767
N4270 G02 X6.3876 Y8.3418 I-0.2167 J-0.1323
N4280 G01 Y8.3408
N4290 G02 X6.3276 Y8.1834 I-0.2214 J-0.0056
N4300 X6.1337 Y8.0993 I-0.2166 J0.2337
N4310 G03 X6.1236 Y8.0420 I0.0021 J-0.0299
N4320 G02 X6.1958 Y7.9971 I-0.1278 J-0.2859
N4330 X6.3002 Y7.8705 I-0.4512 J-0.4784
N4340 G01 X6.4447 Y7.6444
N4350 X6.3495
N4360 X6.2260 Y7.8385
N4370 G03 X6.1292 Y7.9782 I-1.6303 J-1.0264
N4380 X6.0925 Y8.0204 I-0.2668 J-0.1947
N4390 G01 Y8.1447
N4400 G03 X6.1857 Y8.1632 I-0.0418 J0.4547
N4410 G01 X6.1864 Y8.1634
N4420 G03 X6.2796 Y8.2354 I-0.0580 J0.1715
N4430 X6.3112 Y8.3412 I-0.1609 J0.1056
N4440 X6.2493 Y8.4809 I-0.1790 J0.0043
N4450 G01 X6.2474 Y8.4824
N4460 G03 X6.0925 Y8.5347 I-0.1601 J-0.2186
N4470 G01 Y8.5849
N4480 G02 X6.2548 Y8.5592 I-0.0057 J-0.5601
N4490 M62P4 (+++THC Allowed, AD2+++)
N4500 M63P3 (<<<Torch OFF>>>)
N4510 G00 Z1.0000
N4520 X5.6984 Y8.1170
N4530 (>>>Probe/Ref<<<)
N4540 G31.0 Z-10 F19.685
N4550 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N4560 G90 (Back to absolute move mode)
N4570 G92 Z0.0 (Z work coordinate set to 0.0)
N4580 m2020 (HC_WORK_Z_ZEROED=1)
N4590 G4 P0.1
N4600 G00 Z0.3394
N4610 G4 P0.001
N4620 M62P3 (>>>Torch ON<<<)
N4630 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N4640 G04 P0.05
N4650 G01 Z0.3300 F48.0
N4660 M63P4 (***THC Inhibited, AD2***)
N4670 X5.6481 Y8.1070 F33.6
N4680 Y8.5844
N4690 X5.9075
N4700 Y8.5339
N4710 X5.7505
N4720 G03 X5.7205 Y8.5039 I0.0000 J-0.0300
N4730 G01 Y8.4179
N4740 Y8.1731 F48.0
N4750 G03 X5.7505 Y8.1431 I0.0300 J0.0000
N4760 G01 X5.9075
N4770 Y8.0884
N4780 X5.9044 Y8.0885
N4790 X5.9040
N4800 X5.7505
N4810 G03 X5.7205 Y8.0585 I0.0000 J-0.0300
N4820 G01 Y7.6444
N4830 X5.6481
N4840 Y8.1070
N4850 M62P4 (+++THC Allowed, AD2+++)
N4860 M63P3 (<<<Torch OFF>>>)
N4870 G00 Z1.0000
N4880 X5.2851 Y7.7063
N4890 (>>>Probe/Ref<<<)
N4900 G31.0 Z-10 F19.685
N4910 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N4920 G90 (Back to absolute move mode)
N4930 G92 Z0.0 (Z work coordinate set to 0.0)
N4940 m2020 (HC_WORK_Z_ZEROED=1)
N4950 G4 P0.1
N4960 G00 Z0.3394
N4970 G4 P0.001
N4980 M62P3 (>>>Torch ON<<<)
N4990 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N5000 G04 P0.05
N5010 G01 Z0.3300 F48.0
N5020 G02 X5.0404 Y7.6273 I-0.2331 J0.3034
N5030 G01 X5.0382
N5040 G02 X4.7925 Y7.6886 I-0.0196 J0.4446
N5050 X4.6503 Y7.8649 I0.2120 J0.3166
N5060 G01 X4.6501 Y7.8654
N5070 G02 X4.5995 Y8.1217 I0.5997 J0.2514
N5080 G01 Y8.1226
N5090 G02 X4.6561 Y8.3811 I0.5591 J0.0131
N5100 X4.8134 Y8.5447 I0.3393 J-0.1688
N5110 X4.9042 Y8.5824 I0.2229 J-0.4095
N5120 M63P4 (***THC Inhibited, AD2***)
N5130 X5.0412 Y8.6015 I0.1321 J-0.4472
N5140 G01 X5.0426
N5150 G02 X5.2761 Y8.5309 I0.0127 J-0.3797
N5160 X5.3985 Y8.3620 I-0.2235 J-0.2908
N5170 G01 X5.3266 Y8.3451
N5180 G03 X5.2245 Y8.4915 I-0.3193 J-0.1140
N5190 G01 X5.2227 Y8.4928
N5200 G03 X5.0388 Y8.5482 I-0.1736 J-0.2435
N5210 X4.8293 Y8.4878 I-0.0116 J-0.3531
N5220 G01
N5230 M62P4 (+++THC Allowed, AD2+++)
N5240 X4.8288 Y8.4874
N5250 G03 X4.7088 Y8.3240 I0.1863 J-0.2624
N5260 X4.6760 Y8.1229 I0.5944 J-0.2005
N5270 X4.7149 Y7.8896 I0.6401 J-0.0129
N5280 X4.8431 Y7.7321 I0.2888 J0.1040
N5290 X4.8685 Y7.7180 I0.1840 J0.3030
N5300 M63P4 (***THC Inhibited, AD2***)
N5310 X5.0283 Y7.6806 I0.1586 J0.3171
N5320 X5.2359 Y7.7515 I0.0085 J0.3145
N5330 G01 X5.2369 Y7.7524
N5340 G03 X5.3441 Y7.9283 I-0.2394 J0.2664
N5350 G01 X5.4172 Y7.9098
N5360 G02 X5.2851 Y7.7063 I-0.3993 J0.1147
N5370 M62P4 (+++THC Allowed, AD2+++)
N5380 M63P3 (<<<Torch OFF>>>)
N5390 G00 Z1.0000
N5400 X15.2091
N5410 (>>>Probe/Ref<<<)
N5420 G31.0 Z-10 F19.685
N5430 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N5440 G90 (Back to absolute move mode)
N5450 G92 Z0.0 (Z work coordinate set to 0.0)
N5460 m2020 (HC_WORK_Z_ZEROED=1)
N5470 G4 P0.1
N5480 G00 Z0.3394
N5490 G4 P0.001
N5500 M62P3 (>>>Torch ON<<<)
N5510 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N5520 G04 P0.05
N5530 G01 Z0.3300 F48.0
N5540 G02 X14.9645 Y7.6273 I-0.2331 J0.3034
N5550 G01 X14.9623
N5560 G02 X14.7166 Y7.6886 I-0.0196 J0.4446
N5570 X14.5744 Y7.8649 I0.2120 J0.3166
N5580 G01 X14.5741 Y7.8654
N5590 G02 X14.5236 Y8.1217 I0.5997 J0.2514
N5600 G01 Y8.1226
N5610 G02 X14.5802 Y8.3811 I0.5591 J0.0131
N5620 X14.7375 Y8.5447 I0.3393 J-0.1688
N5630 X14.8283 Y8.5824 I0.2229 J-0.4095
N5640 M63P4 (***THC Inhibited, AD2***)
N5650 X14.9653 Y8.6015 I0.1321 J-0.4472
N5660 G01 X14.9666
N5670 G02 X15.2002 Y8.5309 I0.0127 J-0.3797
N5680 X15.3226 Y8.3620 I-0.2235 J-0.2908
N5690 G01 X15.2507 Y8.3451
N5700 G03 X15.1486 Y8.4915 I-0.3193 J-0.1140
N5710 G01 X15.1468 Y8.4928
N5720 G03 X14.9629 Y8.5482 I-0.1736 J-0.2435
N5730 X14.7534 Y8.4878 I-0.0116 J-0.3531
N5740 G01
N5750 M62P4 (+++THC Allowed, AD2+++)
N5760 X14.7528 Y8.4874
N5770 G03 X14.6329 Y8.3240 I0.1863 J-0.2624
N5780 X14.6000 Y8.1229 I0.5944 J-0.2005
N5790 X14.6390 Y7.8896 I0.6401 J-0.0129
N5800 X14.7671 Y7.7321 I0.2888 J0.1040
N5810 X14.7926 Y7.7180 I0.1840 J0.3030
N5820 M63P4 (***THC Inhibited, AD2***)
N5830 X14.9523 Y7.6806 I0.1586 J0.3171
N5840 X15.1599 Y7.7515 I0.0085 J0.3145
N5850 G01 X15.1610 Y7.7524
N5860 G03 X15.2681 Y7.9283 I-0.2394 J0.2664
N5870 G01 X15.3413 Y7.9098
N5880 G02 X15.2091 Y7.7063 I-0.3993 J0.1147
N5890 M62P4 (+++THC Allowed, AD2+++)
N5900 M63P3 (<<<Torch OFF>>>)
N5910 G00 Z1.0000
N5920 X15.7412 Y7.6912
N5930 (>>>Probe/Ref<<<)
N5940 G31.0 Z-10 F19.685
N5950 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N5960 G90 (Back to absolute move mode)
N5970 G92 Z0.0 (Z work coordinate set to 0.0)
N5980 m2020 (HC_WORK_Z_ZEROED=1)
N5990 G4 P0.1
N6000 G00 Z0.3394
N6010 G4 P0.001
N6020 M62P3 (>>>Torch ON<<<)
N6030 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N6040 G04 P0.05
N6050 G01 Z0.3300 F48.0
N6060 G02 X15.5843 Y7.8647 I0.2121 J0.3496
N6070 X15.5299 Y8.1013 I0.4806 J0.2350
N6080 G01 Y8.1032
N6090 G02 X15.5301 Y8.1668 I0.5125 J0.0300
N6100 M63P4 (***THC Inhibited, AD2***)
N6110 X15.6558 Y8.4710 I0.5123 J-0.0335
N6120 X15.8849 Y8.5952 I0.3071 J-0.2932
N6130 G01 Y8.5372
N6140 G03 X15.7167 Y8.4431 I0.0894 J-0.3573
N6150 G01 X15.7148 Y8.4412
N6160 G03 X15.6063 Y8.0988 I0.3505 J-0.2996
N6170 X15.7109 Y7.7950 I0.4301 J-0.0218
N6180 G01 X15.7114 Y7.7944
N6190 G03 X15.8849 Y7.6909 I0.2582 J0.2359
N6200 G01 Y7.6356
N6210 G02 X15.7412 Y7.6912 I0.0856 J0.4345
N6220 M62P4 (+++THC Allowed, AD2+++)
N6230 M63P3 (<<<Torch OFF>>>)
N6240 G00 Z1.0000
N6250 X16.2132 Y8.5401
N6260 (>>>Probe/Ref<<<)
N6270 G31.0 Z-10 F19.685
N6280 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N6290 G90 (Back to absolute move mode)
N6300 G92 Z0.0 (Z work coordinate set to 0.0)
N6310 m2020 (HC_WORK_Z_ZEROED=1)
N6320 G4 P0.1
N6330 G00 Z0.3394
N6340 G4 P0.001
N6350 M62P3 (>>>Torch ON<<<)
N6360 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N6370 G04 P0.05
N6380 G01 Z0.3300 F48.0
N6390 G02 X16.3709 Y8.3685 I-0.2046 J-0.3462
N6400 X16.4263 Y8.1135 I-0.5138 J-0.2451
N6410 G01 Y8.1125
N6420 G02 X16.4249 Y8.0620 I-0.5592 J-0.0096
N6430 M63P4 (***THC Inhibited, AD2***)
N6440 X16.3680 Y7.8542 I-0.5577 J0.0409
N6450 X16.2065 Y7.6854 I-0.3491 J0.1723
N6460 X16.0699 Y7.6359 I-0.2255 J0.4090
N6470 G01 Y7.6906
N6480 G03 X16.2456 Y7.7955 I-0.0834 J0.3391
N6490 G01 X16.2464 Y7.7965
N6500 G03 X16.3499 Y8.1143 I-0.3505 J0.2898
N6510 X16.3061 Y8.3387 I-0.5422 J0.0108
N6520 X16.1739 Y8.4934 I-0.3186 J-0.1384
N6530 X16.0699 Y8.5377 I-0.1904 J-0.3029
N6540 G01 Y8.5942
N6550 G02 X16.2132 Y8.5401 I-0.0844 J-0.4408
N6560 G01
N6570 M62P4 (+++THC Allowed, AD2+++)
N6580 M63P3 (<<<Torch OFF>>>)
N6590 G00 Z1.0000
N6600 X16.7022 Y8.4920
N6610 (>>>Probe/Ref<<<)
N6620 G31.0 Z-10 F19.685
N6630 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N6640 G90 (Back to absolute move mode)
N6650 G92 Z0.0 (Z work coordinate set to 0.0)
N6660 m2020 (HC_WORK_Z_ZEROED=1)
N6670 G4 P0.1
N6680 G00 Z0.3394
N6690 G4 P0.001
N6700 M62P3 (>>>Torch ON<<<)
N6710 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N6720 G04 P0.05
N6730 G01 Z0.3300 F48.0
N6740 M63P4 (***THC Inhibited, AD2***)
N6750 X16.7404 Y8.5844 F33.6
N6760 X17.2567 Y7.8126
N6770 G03 X17.3117 Y7.8293 I0.0249 J0.0167
N6780 G01 Y7.9844
N6790 Y8.5844 F48.0
N6800 X17.3785
N6810 Y7.6444
N6820 X17.2888
N6830 X16.7725 Y8.4169
N6840 G03 X16.7176 Y8.4002 I-0.0249 J-0.0167
N6850 G01 Y7.6444
N6860 X16.6507
N6870 Y8.5844
N6880 X16.7404
N6890 M62P4 (+++THC Allowed, AD2+++)
N6900 M63P3 (<<<Torch OFF>>>)
N6910 G00 Z1.0000
N6920 X17.6604 Y7.6444
N6930 (>>>Probe/Ref<<<)
N6940 G31.0 Z-10 F19.685
N6950 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N6960 G90 (Back to absolute move mode)
N6970 G92 Z0.0 (Z work coordinate set to 0.0)
N6980 m2020 (HC_WORK_Z_ZEROED=1)
N6990 G4 P0.1
N7000 G00 Z0.3394
N7010 G4 P0.001
N7020 M62P3 (>>>Torch ON<<<)
N7030 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N7040 G04 P0.05
N7050 G01 Z0.3300 F48.0
N7060 Y7.9844
N7070 M63P4 (***THC Inhibited, AD2***)
N7080 Y8.5844
N7090 X17.9368
N7100 Y8.5264
N7110 X17.7627
N7120 G03 X17.7327 Y8.4964 I0.0000 J-0.0300
N7130 G01 Y7.7324
N7140 G03 X17.7627 Y7.7024 I0.0300 J0.0000
N7150 G01 X17.9368
N7160 Y7.6444
N7170 X17.6604
N7180 M62P4 (+++THC Allowed, AD2+++)
N7190 M63P3 (<<<Torch OFF>>>)
N7200 G00 Z1.0000
N7210 X18.1475 Y8.5705
N7220 (>>>Probe/Ref<<<)
N7230 G31.0 Z-10 F19.685
N7240 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N7250 G90 (Back to absolute move mode)
N7260 G92 Z0.0 (Z work coordinate set to 0.0)
N7270 m2020 (HC_WORK_Z_ZEROED=1)
N7280 G4 P0.1
N7290 G00 Z0.3394
N7300 G4 P0.001
N7310 M62P3 (>>>Torch ON<<<)
N7320 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N7330 G04 P0.05
N7340 G01 Z0.3300 F48.0
N7350 G02 X18.2802 Y8.5055 I-0.0655 J-0.3017
N7360 X18.3897 Y8.3474 I-0.2448 J-0.2865
N7370 X18.4272 Y8.1204 I-0.6032 J-0.2161
N7380 G01 Y8.1194
N7390 G02 Y8.1111 I-0.6684 J-0.0102
N7400 M63P4 (***THC Inhibited, AD2***)
N7410 X18.4017 Y7.9262 I-0.6685 J-0.0020
N7420 X18.3377 Y7.7894 I-0.4432 J0.1241
N7430 X18.2546 Y7.7065 I-0.2726 J0.1902
N7440 X18.1459 Y7.6608 I-0.1845 J0.2869
N7450 G01 X18.1218 Y7.6565
N7460 Y7.7177
N7470 X18.1383 Y7.7216
N7480 X18.1400 Y7.7221
N7490 G03 X18.2418 Y7.7809 I-0.0717 J0.2416
N7500 G01 X18.2429 Y7.7820
N7510 G03 X18.3232 Y7.9206 I-0.2506 J0.2378
N7520 X18.3507 Y8.1214 I-0.6209 J0.1875
N7530 X18.2959 Y8.3768 I-0.4946 J0.0274
N7540 G01 X18.2955 Y8.3776
N7550 G03 X18.1558 Y8.5035 I-0.2530 J-0.1401
N7560 G01 X18.1510 Y8.5051
N7570 X18.1218 Y8.5121
N7580 Y8.5744
N7590 X18.1475 Y8.5705
N7600 M62P4 (+++THC Allowed, AD2+++)
N7610 M63P3 (<<<Torch OFF>>>)
N7620 G00 Z1.0000
N7630 X18.7636 Y8.5844
N7640 (>>>Probe/Ref<<<)
N7650 G31.0 Z-10 F19.685
N7660 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N7670 G90 (Back to absolute move mode)
N7680 G92 Z0.0 (Z work coordinate set to 0.0)
N7690 m2020 (HC_WORK_Z_ZEROED=1)
N7700 G4 P0.1
N7710 G00 Z0.3394
N7720 G4 P0.001
N7730 M62P3 (>>>Torch ON<<<)
N7740 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N7750 G04 P0.05
N7760 G01 Z0.3300 F48.0
N7770 Y8.2444
N7780 M63P4 (***THC Inhibited, AD2***)
N7790 Y7.6444
N7800 X18.6913
N7810 Y8.5844
N7820 X18.7636
N7830 M62P4 (+++THC Allowed, AD2+++)
N7840 M63P3 (<<<Torch OFF>>>)
N7850 G00 Z1.0000
N7860 X18.9824 Y8.5264
N7870 (>>>Probe/Ref<<<)
N7880 G31.0 Z-10 F19.685
N7890 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N7900 G90 (Back to absolute move mode)
N7910 G92 Z0.0 (Z work coordinate set to 0.0)
N7920 m2020 (HC_WORK_Z_ZEROED=1)
N7930 G4 P0.1
N7940 G00 Z0.3394
N7950 G4 P0.001
N7960 M62P3 (>>>Torch ON<<<)
N7970 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N7980 G04 P0.05
N7990 G01 Z0.3300 F48.0
N8000 M63P4 (***THC Inhibited, AD2***)
N8010 Y8.5844
N8020 X19.7150
N8030 Y8.5264
N8040 X19.4142
N8050 G03 X19.3842 Y8.4964 I0.0000 J-0.0300
N8060 G01 Y7.6444
N8070 X19.3118
N8080 Y8.4964
N8090 G03 X19.2818 Y8.5264 I-0.0300 J0.0000
N8100 G01 X18.9824
N8110 M62P4 (+++THC Allowed, AD2+++)
N8120 M63P3 (<<<Torch OFF>>>)
N8130 G00 Z1.0000
N8140 X20.0031 Y8.5844
N8150 (>>>Probe/Ref<<<)
N8160 G31.0 Z-10 F19.685
N8170 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N8180 G90 (Back to absolute move mode)
N8190 G92 Z0.0 (Z work coordinate set to 0.0)
N8200 m2020 (HC_WORK_Z_ZEROED=1)
N8210 G4 P0.1
N8220 G00 Z0.3394
N8230 G4 P0.001
N8240 M62P3 (>>>Torch ON<<<)
N8250 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N8260 G04 P0.05
N8270 G01 Z0.3300 F48.0
N8280 Y8.2444
N8290 M63P4 (***THC Inhibited, AD2***)
N8300 Y7.6444
N8310 X19.9307
N8320 Y8.5844
N8330 X20.0031
N8340 M62P4 (+++THC Allowed, AD2+++)
N8350 M63P3 (<<<Torch OFF>>>)
N8360 G00 Z1.0000
N8370 X20.9399 Y8.5401
N8380 (>>>Probe/Ref<<<)
N8390 G31.0 Z-10 F19.685
N8400 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N8410 G90 (Back to absolute move mode)
N8420 G92 Z0.0 (Z work coordinate set to 0.0)
N8430 m2020 (HC_WORK_Z_ZEROED=1)
N8440 G4 P0.1
N8450 G00 Z0.3394
N8460 G4 P0.001
N8470 M62P3 (>>>Torch ON<<<)
N8480 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N8490 G04 P0.05
N8500 G01 Z0.3300 F48.0
N8510 G02 X21.0976 Y8.3685 I-0.2046 J-0.3462
N8520 X21.1530 Y8.1135 I-0.5138 J-0.2451
N8530 G01 Y8.1125
N8540 G02 X21.1515 Y8.0620 I-0.5592 J-0.0096
N8550 M63P4 (***THC Inhibited, AD2***)
N8560 X21.0947 Y7.8542 I-0.5577 J0.0409
N8570 X20.9332 Y7.6854 I-0.3491 J0.1723
N8580 X20.7966 Y7.6359 I-0.2255 J0.4090
N8590 G01 Y7.6906
N8600 G03 X20.9723 Y7.7955 I-0.0834 J0.3391
N8610 G01 X20.9731 Y7.7965
N8620 G03 X21.0765 Y8.1143 I-0.3505 J0.2898
N8630 X21.0328 Y8.3387 I-0.5422 J0.0108
N8640 X20.9006 Y8.4934 I-0.3186 J-0.1384
N8650 X20.7966 Y8.5377 I-0.1904 J-0.3029
N8660 G01 Y8.5942
N8670 G02 X20.9399 Y8.5401 I-0.0844 J-0.4408
N8680 G01
N8690 M62P4 (+++THC Allowed, AD2+++)
N8700 M63P3 (<<<Torch OFF>>>)
N8710 G00 Z1.0000
N8720 X21.4289 Y8.4920
N8730 (>>>Probe/Ref<<<)
N8740 G31.0 Z-10 F19.685
N8750 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N8760 G90 (Back to absolute move mode)
N8770 G92 Z0.0 (Z work coordinate set to 0.0)
N8780 m2020 (HC_WORK_Z_ZEROED=1)
N8790 G4 P0.1
N8800 G00 Z0.3394
N8810 G4 P0.001
N8820 M62P3 (>>>Torch ON<<<)
N8830 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N8840 G04 P0.05
N8850 G01 Z0.3300 F48.0
N8860 M63P4 (***THC Inhibited, AD2***)
N8870 X21.4671 Y8.5844 F33.6
N8880 X21.9834 Y7.8126
N8890 G03 X22.0384 Y7.8293 I0.0249 J0.0167
N8900 G01 Y7.9844
N8910 Y8.5844 F48.0
N8920 X22.1052
N8930 Y7.6444
N8940 X22.0155
N8950 X21.4992 Y8.4169
N8960 G03 X21.4443 Y8.4002 I-0.0249 J-0.0167
N8970 G01 Y7.6444
N8980 X21.3774
N8990 Y8.5844
N9000 X21.4671
N9010 M62P4 (+++THC Allowed, AD2+++)
N9020 M63P3 (<<<Torch OFF>>>)
N9030 G00 Z1.0000
N9040 X22.4819
N9050 (>>>Probe/Ref<<<)
N9060 G31.0 Z-10 F19.685
N9070 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N9080 G90 (Back to absolute move mode)
N9090 G92 Z0.0 (Z work coordinate set to 0.0)
N9100 m2020 (HC_WORK_Z_ZEROED=1)
N9110 G4 P0.1
N9120 G00 Z0.3394
N9130 G4 P0.001
N9140 M62P3 (>>>Torch ON<<<)
N9150 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N9160 G04 P0.05
N9170 G01 Z0.3300 F48.0
N9180 Y8.2444
N9190 M63P4 (***THC Inhibited, AD2***)
N9200 Y7.6444
N9210 X22.4096
N9220 Y8.5844
N9230 X22.4819
N9240 M62P4 (+++THC Allowed, AD2+++)
N9250 M63P3 (<<<Torch OFF>>>)
N9260 G00 Z1.0000
N9270 X22.8259 Y8.4920
N9280 (>>>Probe/Ref<<<)
N9290 G31.0 Z-10 F19.685
N9300 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N9310 G90 (Back to absolute move mode)
N9320 G92 Z0.0 (Z work coordinate set to 0.0)
N9330 m2020 (HC_WORK_Z_ZEROED=1)
N9340 G4 P0.1
N9350 G00 Z0.3394
N9360 G4 P0.001
N9370 M62P3 (>>>Torch ON<<<)
N9380 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N9390 G04 P0.05
N9400 G01 Z0.3300 F48.0
N9410 M63P4 (***THC Inhibited, AD2***)
N9420 X22.8641 Y8.5844 F33.6
N9430 X23.3804 Y7.8126
N9440 G03 X23.4354 Y7.8293 I0.0249 J0.0167
N9450 G01 Y7.9844
N9460 Y8.5844 F48.0
N9470 X23.5022
N9480 Y7.6444
N9490 X23.4125
N9500 X22.8962 Y8.4169
N9510 G03 X22.8412 Y8.4002 I-0.0249 J-0.0167
N9520 G01 Y7.6444
N9530 X22.7744
N9540 Y8.5844
N9550 X22.8641
N9560 M62P4 (+++THC Allowed, AD2+++)
N9570 M63P3 (<<<Torch OFF>>>)
N9580 G00 Z1.0000
N9590 X22.0639 Y6.9877
N9600 (>>>Probe/Ref<<<)
N9610 G31.0 Z-10 F19.685
N9620 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N9630 G90 (Back to absolute move mode)
N9640 G92 Z0.0 (Z work coordinate set to 0.0)
N9650 m2020 (HC_WORK_Z_ZEROED=1)
N9660 G4 P0.1
N9670 G00 Z0.3394
N9680 G4 P0.001
N9690 M62P3 (>>>Torch ON<<<)
N9700 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N9710 G04 P0.05
N9720 G01 Z0.3300 F48.0
N9730 M63P4 (***THC Inhibited, AD2***)
N9740 X22.0084 Y7.0709 F33.6
N9750 X23.0084 Y7.0698
N9760 M62P4 (+++THC Allowed, AD2+++)
N9770 X24.0817 Y7.0688 F48.0
N9780 M63P4 (***THC Inhibited, AD2***)
N9790 X24.6817 Y7.0682
N9800 X24.6805 Y6.4682
N9810 M62P4 (+++THC Allowed, AD2+++)
N9820 X24.6793 Y5.8461
N9830 M63P4 (***THC Inhibited, AD2***)
N9840 X24.6781 Y5.2461
N9850 G03 X24.7078 Y5.2160 I0.0300 J-0.0001
N9860 G01 X25.7155 Y5.2055
N9870 X25.3018 Y4.7709
N9880 M62P4 (+++THC Allowed, AD2+++)
N9890 X23.7634 Y3.1545
N9900 M63P4 (***THC Inhibited, AD2***)
N9910 X23.3497 Y2.7198
N9920 X22.9112 Y3.1293
N9930 M62P4 (+++THC Allowed, AD2+++)
N9940 X21.1625 Y4.7618
N9950 M63P4 (***THC Inhibited, AD2***)
N9960 X20.7240 Y5.1713
N9970 X21.3240 Y5.1722
N9980 M62P4 (+++THC Allowed, AD2+++)
N9990 X21.3500
N10000 M63P4 (***THC Inhibited, AD2***)
N10010 X21.9500 Y5.1731
N10020 G03 X21.9800 Y5.2027 I-0.0000 J0.0300
N10030 G01 X21.9891 Y5.8026
N10040 M62P4 (+++THC Allowed, AD2+++)
N10050 X22.0084 Y7.0709
N10060 M63P3 (<<<Torch OFF>>>)
N10070 G00 Z1.0000
N10080 X20.4679 Y7.6912
N10090 (>>>Probe/Ref<<<)
N10100 G31.0 Z-10 F19.685
N10110 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N10120 G90 (Back to absolute move mode)
N10130 G92 Z0.0 (Z work coordinate set to 0.0)
N10140 m2020 (HC_WORK_Z_ZEROED=1)
N10150 G4 P0.1
N10160 G00 Z0.3394
N10170 G4 P0.001
N10180 M62P3 (>>>Torch ON<<<)
N10190 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N10200 G04 P0.05
N10210 G01 Z0.3300 F48.0
N10220 G02 X20.3110 Y7.8647 I0.2121 J0.3496
N10230 X20.2566 Y8.1013 I0.4806 J0.2350
N10240 G01 Y8.1032
N10250 G02 X20.2568 Y8.1668 I0.5125 J0.0300
N10260 M63P4 (***THC Inhibited, AD2***)
N10270 X20.3825 Y8.4710 I0.5123 J-0.0335
N10280 X20.6116 Y8.5952 I0.3071 J-0.2932
N10290 G01 Y8.5372
N10300 G03 X20.4433 Y8.4431 I0.0894 J-0.3573
N10310 G01 X20.4415 Y8.4412
N10320 G03 X20.3330 Y8.0988 I0.3505 J-0.2996
N10330 X20.4376 Y7.7950 I0.4301 J-0.0218
N10340 G01 X20.4381 Y7.7944
N10350 G03 X20.6116 Y7.6909 I0.2582 J0.2359
N10360 G01 Y7.6356
N10370 G02 X20.4679 Y7.6912 I0.0856 J0.4345
N10380 G01
N10390 M62P4 (+++THC Allowed, AD2+++)
N10400 M63P3 (<<<Torch OFF>>>)
N10410 G00 Z1.0000
N10420 X24.6156 Y8.0946
N10430 (>>>Probe/Ref<<<)
N10440 G31.0 Z-10 F19.685
N10450 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N10460 G90 (Back to absolute move mode)
N10470 G92 Z0.0 (Z work coordinate set to 0.0)
N10480 m2020 (HC_WORK_Z_ZEROED=1)
N10490 G4 P0.1
N10500 G00 Z0.3394
N10510 G4 P0.001
N10520 M62P3 (>>>Torch ON<<<)
N10530 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N10540 G04 P0.05
N10550 G01 Z0.3300 F48.0
N10560 M63P4 (***THC Inhibited, AD2***)
N10570 Y7.7680
N10580 G02 X24.4336 Y7.6646 I-0.4420 J0.5658
N10590 X24.2316 Y7.6273 I-0.2020 J0.5296
N10600 G01 X24.2312
N10610 G02 X24.0514 Y7.6558 I-0.0071 J0.5378
N10620 M62P4 (+++THC Allowed, AD2+++)
N10630 X23.9776 Y7.6871 I0.1727 J0.5094
N10640 X23.8088 Y7.8564 I0.1765 J0.3447
N10650 X23.7507 Y8.1092 I0.4863 J0.2450
N10660 G01 Y8.1098
N10670 G02 X23.8088 Y8.3691 I0.5889 J0.0042
N10680 G01 X23.8090 Y8.3696
N10690 G02 X23.9714 Y8.5435 I0.3419 J-0.1565
N10700 X24.1058 Y8.5910 I0.2388 J-0.4624
N10710 M63P4 (***THC Inhibited, AD2***)
N10720 X24.2207 Y8.6015 I0.1044 J-0.5099
N10730 G01 X24.2218
N10740 G02 X24.4066 Y8.5683 I0.0071 J-0.4930
N10750 X24.5313 Y8.4799 I-0.1030 J-0.2773
N10760 X24.5940 Y8.3558 I-0.3240 J-0.2416
N10770 G01 X24.5315 Y8.3386
N10780 G03 X24.4798 Y8.4394 I-0.3777 J-0.1301
N10790 G01 X24.4787 Y8.4409
N10800 G03 X24.3710 Y8.5198 I-0.2021 J-0.1627
N10810 X24.2222 Y8.5482 I-0.1443 J-0.3518
N10820 X24.0542 Y8.5185 I-0.0096 J-0.4356
N10830 X24.0311 Y8.5083 I0.1183 J-0.3006
N10840 M62P4 (+++THC Allowed, AD2+++)
N10850 X23.9365 Y8.4384 I0.1415 J-0.2904
N10860 X23.8676 Y8.3307 I0.2792 J-0.2542
N10870 G01 X23.8675 Y8.3303
N10880 G03 X23.8271 Y8.1182 I0.5129 J-0.2076
N10890 X23.8760 Y7.8813 I0.5180 J-0.0165
N10900 G01 X23.8763 Y7.8808
N10910 G03 X23.9756 Y7.7627 I0.2910 J0.1440
N10920 M63P4 (***THC Inhibited, AD2***)
N10930 X24.0239 Y7.7335 I0.1916 J0.2621
N10940 X24.2242 Y7.6867 I0.1986 J0.3982
N10950 X24.4027 Y7.7218 I-0.0004 J0.4740
N10960 X24.5350 Y7.7971 I-0.1599 J0.4346
N10970 X24.5460 Y7.8204 I-0.0189 J0.0233
N10980 G01 Y8.0066
N10990 G03 X24.5160 Y8.0366 I-0.0300 J0.0000
N11000 G01 X24.2520
N11010 Y8.0940
N11020 X24.6156 Y8.0946
N11030 M62P4 (+++THC Allowed, AD2+++)
N11040 M63P3 (<<<Torch OFF>>>)
N11050 G00 Z1.0000
N11060 X21.9548 Y11.6764
N11070 (>>>Probe/Ref<<<)
N11080 G31.0 Z-10 F19.685
N11090 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N11100 G90 (Back to absolute move mode)
N11110 G92 Z0.0 (Z work coordinate set to 0.0)
N11120 m2020 (HC_WORK_Z_ZEROED=1)
N11130 G4 P0.1
N11140 G00 Z0.3394
N11150 G4 P0.001
N11160 M62P3 (>>>Torch ON<<<)
N11170 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N11180 G04 P0.05
N11190 G01 Z0.3300 F48.0
N11200 M63P4 (***THC Inhibited, AD2***)
N11210 X22.0258 Y11.6060 F33.6
N11220 X21.3218 Y10.8958
N11230 M62P4 (+++THC Allowed, AD2+++)
N11240 X20.0491 Y9.6120 F48.0
N11250 M63P4 (***THC Inhibited, AD2***)
N11260 X19.6267 Y9.1859
N11270 X19.0267 Y9.1843
N11280 M62P4 (+++THC Allowed, AD2+++)
N11290 X16.6479 Y9.1780
N11300 M63P4 (***THC Inhibited, AD2***)
N11310 X16.0479 Y9.1764
N11320 X16.4721 Y9.6007
N11330 M62P4 (+++THC Allowed, AD2+++)
N11340 X21.7160 Y14.8452
N11350 M63P4 (***THC Inhibited, AD2***)
N11360 X22.1403 Y15.2695
N11370 X22.7403
N11380 M62P4 (+++THC Allowed, AD2+++)
N11390 X24.0980
N11400 M63P4 (***THC Inhibited, AD2***)
N11410 X24.6980
N11420 X24.6968 Y14.6695
N11430 M62P4 (+++THC Allowed, AD2+++)
N11440 X24.6871 Y9.7993
N11450 M63P4 (***THC Inhibited, AD2***)
N11460 X24.6859 Y9.1993
N11470 X24.0859 Y9.1977
N11480 M62P4 (+++THC Allowed, AD2+++)
N11490 X22.6407 Y9.1939
N11500 M63P4 (***THC Inhibited, AD2***)
N11510 X22.0407 Y9.1923
N11520 X22.0498 Y9.7922
N11530 M62P4 (+++THC Allowed, AD2+++)
N11540 X22.0771 Y11.5844
N11550 M63P3 (<<<Torch OFF>>>)
N11560 G00 Z1.0000
N11570 X29.2500 Y17.2600
N11580 (>>>Probe/Ref<<<)
N11590 G31.0 Z-10 F19.685
N11600 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N11610 G90 (Back to absolute move mode)
N11620 G92 Z0.0 (Z work coordinate set to 0.0)
N11630 m2020 (HC_WORK_Z_ZEROED=1)
N11640 G4 P0.1
N11650 G00 Z0.3394
N11660 G4 P0.001
N11670 M62P3 (>>>Torch ON<<<)
N11680 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N11690 G04 P0.05
N11700 G01 Z0.3300 F48.0
N11710 M63P4 (***THC Inhibited, AD2***)
N11720 Y17.1800 F33.6
N11730 G02 I0.0000 J0.0700
N11740 M62P4 (+++THC Allowed, AD2+++)
N11750 M63P3 (<<<Torch OFF>>>)
N11760 G00 Z1.0000
N11770 X15.1763 Y4.8384
N11780 (>>>Probe/Ref<<<)
N11790 G31.0 Z-10 F19.685
N11800 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N11810 G90 (Back to absolute move mode)
N11820 G92 Z0.0 (Z work coordinate set to 0.0)
N11830 m2020 (HC_WORK_Z_ZEROED=1)
N11840 G4 P0.1
N11850 G00 Z0.3394
N11860 G4 P0.001
N11870 M62P3 (>>>Torch ON<<<)
N11880 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N11890 G04 P0.05
N11900 G01 Z0.3300 F48.0
N11910 M63P4 (***THC Inhibited, AD2***)
N11920 X15.2500 Y4.7708 F33.6
N11930 G02 X14.5183 Y4.0907 I-4.6263 J4.2436
N11940 M62P4 (+++THC Allowed, AD2+++)
N11950 X4.8598 Y6.5270 I-3.8946 J4.9237 F48.0
N11960 M63P4 (***THC Inhibited, AD2***)
N11970 X4.6487 Y7.0884 I5.7640 J2.4875
N11980 G01 X5.2487 Y7.0878
N11990 M62P4 (+++THC Allowed, AD2+++)
N12000 X6.8615 Y7.0862
N12010 M63P4 (***THC Inhibited, AD2***)
N12020 X7.4615 Y7.0855
N12030 G03 X7.8129 Y6.6000 I3.1762 J1.9289
N12040 M62P4 (+++THC Allowed, AD2+++)
N12050 X13.3943 Y6.5224 I2.8248 J2.4144
N12060 G01 X13.5265 Y6.6547
N12070 M63P4 (***THC Inhibited, AD2***)
N12080 X13.9507 Y7.0790
N12090 X14.5507 Y7.0784
N12100 M62P4 (+++THC Allowed, AD2+++)
N12110 X16.9345 Y7.0760
N12120 M63P4 (***THC Inhibited, AD2***)
N12130 X17.5345 Y7.0754
N12140 X17.1121 Y6.6493
N12150 M62P4 (+++THC Allowed, AD2+++)
N12160 X15.2508 Y4.7717
N12170 X15.2500 Y4.7708
N12180 M63P3 (<<<Torch OFF>>>)
N12190 G00 X15.2508 Y4.7717 Z1.0000
N12200 X0.7500 Y17.2600
N12210 (>>>Probe/Ref<<<)
N12220 G31.0 Z-10 F19.685
N12230 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N12240 G90 (Back to absolute move mode)
N12250 G92 Z0.0 (Z work coordinate set to 0.0)
N12260 m2020 (HC_WORK_Z_ZEROED=1)
N12270 G4 P0.1
N12280 G00 Z0.3394
N12290 G4 P0.001
N12300 M62P3 (>>>Torch ON<<<)
N12310 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N12320 G04 P0.05
N12330 G01 Z0.3300 F48.0
N12340 M63P4 (***THC Inhibited, AD2***)
N12350 Y17.1800 F33.6
N12360 G02 I0.0000 J0.0700
N12370 M62P4 (+++THC Allowed, AD2+++)
N12380 M63P3 (<<<Torch OFF>>>)
N12390 G00 Z1.0000
N12400 X29.2500 Y-0.1300
N12410 (>>>Probe/Ref<<<)
N12420 G31.0 Z-10 F19.685
N12430 G91 G00 Z0.0591 (Incremental move for switch offset distance comp)
N12440 G90 (Back to absolute move mode)
N12450 G92 Z0.0 (Z work coordinate set to 0.0)
N12460 m2020 (HC_WORK_Z_ZEROED=1)
N12470 G4 P0.1
N12480 G00 Z0.3394
N12490 G4 P0.001
N12500 M62P3 (>>>Torch ON<<<)
N12510 Z0.3000 (Force a small move in Z to make M62 fire the torch)
N12520 G04 P0.05
N12530 G01 Z0.3300 F48.0
N12540 M63P4 (***THC Inhibited, AD2***)
N12550 Y-0.0300 F33.6
N12560 G03 X29.9977 Y0.5279 I0.0000 J0.7800
N12570 M62P4 (+++THC Allowed, AD2+++)
N12580 X30.0300 Y0.7500 I-0.7477 J0.2221 F48.0
N12590 G01 Y17.2500
N12600 G03 X29.2500 Y18.0300 I-0.7800 J0.0000
N12610 G01 X0.7500
N12620 G03 X-0.0300 Y17.2500 I0.0000 J-0.7800
N12630 G01 Y0.7500
N12640 G03 X0.7500 Y-0.0300 I0.7800 J0.0000
N12650 G01 X29.2500
N12660 M63P3 (<<<Torch OFF>>>)
N12670 G00 Z1.0000
N12680 Z1.0039
N12690 G92.1
N12700 M30
I meant to post if in dxf format so we can see what your are starting with.
Ok I look over you G-code and I am not a user THC3in1 so I don't know what or why some commands are used in the G-code. But after torch start (line 3700)
there seems to be great increase in the use of M63P4 inhibited AD2 and M63p4 allowed AD2 commands in that cut operation and the ones following it.
You may want to find why that happens. In the cut operation before that there is one inhibited and one allowed per cut.
I think we need to start by having a look at the original dxf this gcode was generated from. What software are you using on your computer to draw the files that do cut, and what program are you using to generate the gcode? If you post one of your "problem" dxf files and I am able to cut it with no problems, then we know it is not a problem with the dxf file - but more likely a problem with the method and/or software you are using to process the dxf to create the gcode specific to your machine.
Heres the same file that i posted up above. I draw in QCAD, then go too sheetcam and then mach 4. I have used qcad, sheetcam and mach 3 for probably 8-10 years with no problems. Now that i changed too mach 4 and my new THC im having the problems... also i am on a completely new computer too. Files that i store on a flash drive that i have drawn and cut before i can open in qcad, save them, run them through sheetcam with my new post set up and cut in mach 4..... But say i download a file from here, save it, run it through sheetcam and then try and cut in mach 4 it will shut down mach 4. Even files that i have in my emails that i have drawn before and cut, if i download them from my email and try and cut them it will shut down mach 4. its so weirdadbuch wrote: ↑Thu Dec 10, 2020 8:10 pm I think we need to start by having a look at the original dxf this gcode was generated from. What software are you using on your computer to draw the files that do cut, and what program are you using to generate the gcode? If you post one of your "problem" dxf files and I am able to cut it with no problems, then we know it is not a problem with the dxf file - but more likely a problem with the method and/or software you are using to process the dxf to create the gcode specific to your machine.
- Attachments
- creative air.dxf
- (135.45 KiB) Downloaded 39 times
Is the file you just provided (creative air conditioning) causing Mach4 to shut down?
If so, where did you get this file? From you flash drive, or downloaded from Plasmaspider?
In any case, I see nothing wrong with this file.
I opened your file - It has 101 paths and 1970 nodes as imported, and 35 paths with 1904 nodes after linking.
I don't see any problems with the file, and it would cut on my table just fine. I believe your problem is occurring during your processing.
Yes this was the file, and this is actually the first one i had a problem with that i had drawn. But I did download their logo into qcad too trace so i fugured it still had something funky with having a download involved. So how could my processing in sheetcam be telling mach 4 too shut down? it literally closes the program
By your saying it closes the program, do you mean like you clicked on the X in the top corner, as you would end a program. Or is it different, like the program stops functioning and you need to terminate it.
Closes like I click the x in the corner. ill look back at the computer and the mach screen is completely gone and closed.acourtjester wrote: ↑Fri Dec 11, 2020 2:23 pm By your saying it closes the program, do you mean like you clicked on the X in the top corner, as you would end a program. Or is it different, like the program stops functioning and you need to terminate it.
that sounds like a computer error, I have only used Mach 4 once. With Mach 3 you can run a G-code without a table. Have you tried to run mach 4 with your table turned off. If you have a ohmic sensor or floating head you may need to make a new G-code without those options like a generic post processor. The run that same file to see what happens.
thats not a bad idea. ill try running it right now
So I cant get it too run without the plasma on. I did copy and paste the file too a new name file and ran it through sheetcam again and it still crashed mach 4 in the same exact spot of the cut.
Yes it is looking for the Arc OK signal, not sure about Mach 4 but you can make a hotkey to simulate the Arc OK or change the input pin to active HI that should make it on all the time. The lines I marked seem to be related to the THC on/off while cutting, are you using cut rules in SheetCam? You may trying to turn them off when making a new G-code. It seems odd that it is doing that so many time after 10 cuts acting normally, unless there are a lot of short lines with changes of directions
I am using some rules that are recommended but the manufacturer. Ill try running it without those. Also i noticed the program shut down right around line 4000 which is right in the zone you mentioned before
So i shut my rules off, and the file ran. Then i opened another file that was not cutting, ran it back through sheetcam and it cut. The rules were shutting it down. YOU ARE THE MAN. I definitely owe you a couple brewskis.acourtjester wrote: ↑Fri Dec 11, 2020 4:27 pm Yes it is looking for the Arc OK signal, not sure about Mach 4 but you can make a hotkey to simulate the Arc OK or change the input pin to active HI that should make it on all the time. The lines I marked seem to be related to the THC on/off while cutting, are you using cut rules in SheetCam? You may trying to turn them off when making a new G-code. It seems odd that it is doing that so many time after 10 cuts acting normally, unless there are a lot of short lines with changes of directions
That's great! Problem solved.
Happy to help and thanks for completing the post as that may help another in the future if they use the search function for similar questions. ![Very Happy :-D](./images/smilies/icon_e_biggrin.gif)
